Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
If you change the window size, Poser will want to try and force the render back to whatever you had before -- you'll see this with dark grey sections top and bottom, which are outside whatever Poser considers the "live area". Go to render dimensions, click on render to current window size, then see what happens when you return to preview.
I am still plugging away with poser 5, but I've just run across a new problem. My render is cutting off the top of Michael's head. (scowl) I Know there's a simple solution to this but so far I'm not finding it. I'd appreciate some input. Thanks much
myst
