Attached Link: http://drgeep.com
Render> **Render Dimenisions>** Set -Select-Render to exact resolution-Width, Height, ( large as you want or the largest you computer can handle ), Set Resolution at 300 dpi>Render>
**Render Settings>
**Set quailty to FINAL
Render in Firefly
I'm still learning Poser 7 myself, I hope this helps. I used PoserPropack until recently. The people here a Renderosity have really helped me a lot.
If you need screen shots let me know.
BTW, Dr Geep and PU can be a great help.
If you are going for detail & quality you may want to try these options:
Turn off texture filtering on your materials.
Have your min shading rate on your figures & render settings low, try for between 0.1 - 0.2.
Have your irradiance caching as high as possible.
Increase your pixel samples.
Sorry I can't go into more detail, I've been up for over two days & I'm falling asleep as I'm typing..................................................................................
Quote - Render>
Render Dimenisions>
Set Resolution at 300 dpi>.....
Hello,
I just found out a problem...I can't render in an other resolution than 72 dpi.
(I never needed to before....)
I tried every option in the Render Dimension window and saved in several formats, the outcome
was always only 72 dpi?
I'm totally at a loss, what's going wrong here?
I'm using Poser 7 on a new computer with 2 GB RAM
(Poser works very unstable and I can only using SreeD...had never such problems before)
I'm grateful for any hint!
Nothing is going wrong as such, Poser will always render at 72dpi, it's just the way it is and unless addressed by a service release will remain so.
If you are rendering for print purposes then you need to do a little maths to work out the final size you need for the print project and then change your resolution in an image manipulation program.
The problems you are having with Poser 7 sound like a graphics card problem, look to see if there is a driver update for your particular card as that will likely fix your problem (just because it is a new PC doesn't mean that it has the latest drivers installed especially if it has been bought "off the shelf" rather than built to spec.
" Try and be nice to people, avoid eating fat, read a good
book every now and then, get some walking in, and try and live
together in peace and harmony with people of all creeds and
nations."
-Monty Python
My bad as all of that was for ladyperwinkle not at philywebrider.. didn't scroll up to the top to get the OPs name. :oops:
nations."
-Monty Python
How do I render in Poser 7 where the characters are nice and big and not so blurry, so when I export them as png files and bring them into Adobe Photoshop they are nice and big and crystal clear. I use the smooth button, I am not sure if I am missing a step. Can someone help me. Thank you
