Fri, Nov 22, 11:25 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: underwater vue scenes
Zak666Williams ( ) posted Fri, 04 January 2008 at 12:49 PM · edited Thu, 21 November 2024 at 11:10 AM
dose anyone know of a good tutorial for underwater scenes?
of where i could get a free one?
Peggy_Walters ( ) posted Fri, 04 January 2008 at 1:13 PM
I have one - it's based on Vue 5, but will work just as well in Vue 6.
http://users.tns.net/~mwalter1/caustics.pdf
Then, take a look over at GeekatPlay.  Lots of tutorials and one on underwater.
http://geekatplay.com/index.php  See tutorial #30
P.S.  My tutorials will not be available on my site for much longer - I will be moving them to ShareCG (they host for free and are quick for downloads).
Peggy
LVS - Where Learning is Fun!
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 1:29 PM
Excellent links and really good tutorials ! Thanks Peggy_Walters
Zak666Williams ( ) posted Fri, 04 January 2008 at 1:40 PM
Dam i can't open the link for the first one.
Zak666Williams ( ) posted Fri, 04 January 2008 at 1:44 PM
I had a look at the tutorials on the greek site, but  In Vue 6 Esprite i cant find the option in eadeting materials that lets you create your own ecosystems.
but the underwater one wont run on my pc for some reaseon.
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 1:52 PM
Quote - Dam i can't open the link for the first one.
I can open it... it's in .pdf.
For Vue6 infinite, I don't know, but work good in vue6 XS
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 1:58 PM
You cannot make that ?
Zak666Williams ( ) posted Fri, 04 January 2008 at 1:59 PM · edited Fri, 04 January 2008 at 2:00 PM
i've got it now, thanks for the PDF
Now i need a Tutorial for Vue 6 Esprite forgenerating your own ecosystems like in Xstream
alexcoppo ( ) posted Fri, 04 January 2008 at 2:08 PM
Quote - Now i need a Tutorial for Vue 6 Esprite forgenerating your own ecosystems like in Xstream
If you Esprit without additional modules, you can only populate an ecosystem created by someone else. In order to create ecosystems, either get just the Ecosystems additional module (or Vue Pro).
Bye!!
P.S.: instead of  Bye I wrote Buye!!! great freudian lapsus, isn't it?
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 2:13 PM · edited Fri, 04 January 2008 at 2:20 PM
Quote - i've got it now, thanks for the PDF
But.. do you have Vue Esprit or Vue XS ?
Quote - P.S.: instead of  Bye I wrote Buye!!! great freudian lapsus, isn't it?
:lol:
Zak666Williams ( ) posted Fri, 04 January 2008 at 2:20 PM
I've reasently got Vue6 Espite And I think i might just go bye that dam modual.
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 2:28 PM
I don't know this version, sorry.. But the process, I think, still the same...
Zak666Williams ( ) posted Fri, 04 January 2008 at 2:29 PM
in the materials eaditor under the types of material under the one starting with V there is no Ecosystem like in Exstream so Esprite can not do this (DAM)
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 2:47 PM
well... Do you have some material in ecosystem with sub-marine system ? or do you have nothing like that ?
Zak666Williams ( ) posted Fri, 04 January 2008 at 2:57 PM
this water tutorial is awsome, but how do i get a Open Ocean with no ground?
when i preview it just has a wite section at the bottom and when i delete the ground i just get a blue screen
(same thing happends when i try to change the ocean matirial.)
Thanks.
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 2:57 PM
Moment, I think you want to make a ecosystem on understyle and it's hard.. So, see this image and test for to make the same 😄
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 3:11 PM
Ah.. and you don't have Espite, but Vue 6 Esprit ... We have 5 vue6 possibles :### Vue 6 Easel – the easy way to 3D
Vue 6 Esprit – the artist’s choice
Vue 6 Pro Studio – for the advanced artist
Vue 6 Infinite – the stand-alone solution
Vue 6 xStream – the integrated solution
Zak666Williams ( ) posted Fri, 04 January 2008 at 3:19 PM
this is what i came up with although i don't like it that much.
It's to dull and not clean enough and isnot very real.
Valerie-Ducom ( ) posted Fri, 04 January 2008 at 3:29 PM
The better real scene is to make a photograph.
Vue 6 is a program for to creat a virtual scene, but if you want to have a realism in your image, with the textures, bumps and function, you can have some very realist image, but still virtual. See in the gallerie general here and I'm sure you will have a lot surprise...
Arraxxon ( ) posted Fri, 04 January 2008 at 4:35 PM · edited Fri, 04 January 2008 at 4:35 PM
Do you have the Vue sample scenes installed ?
There should be at least two underwater scenes for training and check, how it's set up.
You could even use the atmospheres or whatever as base starts for your own scenes to be changed as you like it.
And there is, too, a scene with a ocean wavy surface, produced with the function editor, could be used as a base water surface to hover above your scenery and to send light through it's surface for water light beam effects or whatever...
silverblade33 ( ) posted Sat, 05 January 2008 at 11:44 AM
Folk use HAZE or fog to simulate underwater conditions ;)
to give "caustics" you can use a light gel applied to a spot light.
MNArtist ( ) posted Sat, 05 January 2008 at 11:50 PM
Hey Gang - A little off-topic here, but I'm having a sudden issue with Vue6E, specifically around underwater scenes, and am wondering if anyone has run into this. My main camera is disappearing from the scene and vue won't allow me to add another one. This is happening regardless of whether I build the scene, then add the water, or whether I start the camera below or above water level. Has anyone ever run into a disappearing camera before?
Peggy_Walters ( ) posted Sun, 06 January 2008 at 11:50 AM
Strange - check your options setting (File, Options) and look at the display tab.  Maybe uncheck both the stop camera to go below clipping plane and clip objects below clipping plane.  Maybe the first is unchecked, but the second one is not - so once camera goes below the water is not displayed...
It should always still be on the browser list though.  If it is disappearing from there - that would be a tech support ticket.
