Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Sep 18 12:22 pm)
The image is made from four separate photographs taken with the digital camera. I then import them into the computer and use a piece of software to "stitch" them together. It's caller Live Picture Photo Vista and is very simple to use. You can also make 180 degree or 360 degree pictures. I can recommend it.
I too have the same program. If you can afford it I recomend getting the ENTIRE Reality Suite. It includes -A Photo Vista Program, A 3D image creation program, A viewer, and a program which will allow you to combine them all to create a 3D world. All you then need is a host and you can create 3D websites. I second Jack's comment the software is strongely recomended. I stiched togeather the sunset panorama I posted below in about 5 minutes max. Bsteph
Attached Link: http://www.jackcasement.btinternet.co.uk/panoramas.htm
Sorry Antoonio, it doesn't work like that. You can't just grab three or four pictures and stitch them together. I always set out to take panoramas which means that when I take the pictures I shoot them, usually left to right, and slightly overlap each picture in the viewfinder. When I started I always used a tripod but I never do now. Just make sure you keep the horizontal the same in each frame and with a little overlap and then let the programme do the rest. It really is very simple and I take no credit for its success in my panoramas. If you haven't already seen my page of panoramas on my web site check them out. They vary from a mixture of three pictures to seven pictures stitched together. The problem I found is that by using too many pictures to make a 180 degree picture is that you end up with a very narrow picture. I usually just use three or four now. Hope this helps.Jack, sure I have seen your galleries. Many times. :o) And I have tried panoramas too, with photoshop. Like you said, 180 and even 360 are really difficult to do, and almost impossible to present. Too narrow results, like you said. The hardest part, or so I think, is to get contrasts right, to do seamless works like you do. .n
Thanks for the tip. You know, photoshop is quite easy too. Just adjust overlapping layers transparency bit, zoom, and its kind of easy to place pics correctly. Adjust transparency back to 100, erase the edges bit, and voila. Like I said, contrasts are the hardest part, but little bit work, and few pics can be done in no time. ...curious to hear your comments about that pixtra-thing, Alpha. .n
I found panorama's to be a pain - maybe it's because of my digi - turning the camera around meant it seemed to read the light differently and I ended off with say a light picture, slightly darker one then a light one again, and no amount of adjustment would get them the same. Probably me just needing more experience!!
