Forum Moderators: RedPhantom
Select the animal, and click on the Materials tab to go the the mat room. Set the diffuse color to white. Right-click on the blank area to the right and choose New Node--2D textures--Image map. Drag from the plug icon in the upper left to the diffuse recepticle on the Poser surface box. That should connect it. Click on the word "None" and you can browse to the image you want to use.
Repeat for each material that uses the map. Use the Materials drop down at the top to pick material zones. When done click on the Pose tab to go back to the Pose room.
John
Quote - Select the animal, and click on the Materials tab to go the the mat room. Set the diffuse color to white. Right-click on the blank area to the right and choose New Node--2D textures--Image map. Drag from the plug icon in the upper left to the diffuse recepticle on the Poser surface box. That should connect it. Click on the word "None" and you can browse to the image you want to use.
John
John, that's awesome, thanks! btw, is it an acceptable practice to leave transparency in the image map and use the underlying diffuse color when coloring a character? (saved file as .png instead of .jpg) Thanks again for such quick help!!!
Quote - btw, is it an acceptable practice to leave transparency in the image map and use the underlying diffuse color when coloring a character? (saved file as .png instead of .jpg) Thanks again for such quick help!!!
I suppose it would work, but I've had bad experiences using pngs as textures -- I think their size causes memory problems.
Hi all, I am new at creating custom characters but downloaded the DAZ animals and noticed there was a template dir with texture maps in jpg form. Inside the file the instructions are to paint the shapes to be applied to the model, but in the modeler room i don't see where the texture map is being used (everything is just colored) and i dont know how to attach the .jpg as a map. Can someone point me to a tut or explain? I am assuming i can just use photoshop to color the say chimptmp.JPG to suit, and somehow apply that to the stock character for Chimp? Well, thanks for your help!!! coocoo
