Sat, Nov 30, 12:45 AM CST
Subject: Anyone want to paint some eyes?
jasonmit ( ) posted Wed, 09 January 2008 at 4:50 AM · edited Sat, 30 November 2024 at 12:36 AM
I've been working on this guardian angel image for a while and I basically have it the way I want it except for the angel's eyes. They look zombie-like. They have no color variation or darker outer ring. They're ... yuck.
Is there anyone good at postwork painting who could make these eyes beautiful? A close-up is below.
jasonmit ( ) posted Wed, 09 January 2008 at 4:52 AM
The eyes.
pakled ( ) posted Wed, 09 January 2008 at 2:59 PM
depends on how you're doing it. If you're using Daz 3d, you might be able to use one of hundreds of eye shades out there, depending on the character (go through the Poser freebies, and search on 'eyes')
Failing that, you could texture them in Bryce itself, if you found a mat you liked. Stay tuned for more helpful answers...;)
bobbystahr ( ) posted Wed, 09 January 2008 at 5:03 PM
Well first off they seem like the colour area is to large for the white so if you could scale that down by as much as 1/3 I think you'd have a nicer looking start point . Or bear this in mind when selecting a new mat...we don't know what this was mapped in so we can't give more specific advice. More details = better help.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
jasonmit ( ) posted Wed, 09 January 2008 at 7:00 PM
The character is Michael 3 and the eyes are those that came with the Michael 3 package. I'm hesitant to pull this back into Daz Studio as I always seem to have to reposition and resize everything when re-importing to Bryce. Thus, the request for postwork painters.
Incarnadine ( ) posted Wed, 09 January 2008 at 8:51 PM
Do you have the eye textures as an image texture? I can probably adapt some of the freebie image textures I have if I have a template to set it up from.
jasonmit ( ) posted Wed, 09 January 2008 at 9:05 PM
Quote - Do you have the eye textures as an image texture? I can probably adapt some of the freebie image textures I have if I have a template to set it up from.
I don't know. How would I find out?
jasonmit ( ) posted Wed, 09 January 2008 at 9:20 PM
Can I go from this to help someone help me?
Incarnadine ( ) posted Wed, 09 January 2008 at 10:14 PM
I thought you were looking for a better map, not someone to post work - my apologies.
You should be able to apply a new map inside bryce by selecting the eye object (or subparts) and adding a better image in the associated material.
Can you show us a screen cap of your eye mat settings in the material manager - curious why it is getting washed out/flattened?
jasonmit ( ) posted Wed, 09 January 2008 at 11:01 PM
> Quote - I thought you were looking for a better map, not someone to post work - my apologies. > You should be able to apply a new map inside bryce by selecting the eye object (or subparts) and adding a better image in the associated material. > Can you show us a screen cap of your eye mat settings in the material manager - curious why it is getting washed out/flattened?
Does this help? i'm looking for anything that will improve the eyes.
boekenwuurm ( ) posted Thu, 10 January 2008 at 5:37 AM · edited Thu, 10 January 2008 at 5:39 AM
For me, the eyes lookes best if Diffusion put to 100, ambience on +/- 15, both with node from the picture. Try to experiment with the specularity, that can change the wole eyes.
 For the , I beleave it is the corona, I select the water material. This should give better results.
Also , this is not a rule, mor a guide I use for meself. there are better tutorials on this on the web, like this one:
http://www.geocities.com/matcreator/tutorial1.html
Good luck.
TheBryster ( ) posted Thu, 10 January 2008 at 7:41 AM · edited Thu, 10 January 2008 at 7:43 AM
Forum Moderator
Jasonmit: *I'm hesitant to pull this back into Daz Studio as I always seem to have to reposition and resize everything when re-importing to Bryce.
*I solve this problem by taking careful note of the position and size BEFORE I go back to DAZ/studio.  Then when I port back to Bryce I just input the data and the model goes back to where it was.
And you could always re-size and re-position the eyes in Bryce anyway.
Analog-X64 ( ) posted Thu, 10 January 2008 at 4:16 PM · edited Thu, 10 January 2008 at 4:17 PM
something like this?
I did this in less than 5 minutes... I could do a better job if I take my time.
Ang25 ( ) posted Thu, 10 January 2008 at 6:12 PM
Those eyes are definately much nicer. It's a Beautiful image you've created.
Analog-X64 ( ) posted Thu, 10 January 2008 at 6:35 PM
I've also slightly changed Contrast and Brightness Levels.
jasonmit ( ) posted Sat, 12 January 2008 at 12:18 AM
Quote - something like this?
That looks reallly good. I'll contact you.
RodsArt ( ) posted Sat, 12 January 2008 at 3:09 AM
The Eyes look decent......but there's something missing.........Eyelashes, which will cast a bit of shadow over the eye to give it contrast. Mike 3 has really nice mats and trans maps for lashes.
Also, I'm not sure why the top of the eylid is so pronounced, it's drawing attention.
___
Ockham's razor- It's that simple
Analog-X64 ( ) posted Sat, 12 January 2008 at 5:21 AM
He was out all night partying and didnt get enough sleep. :)
