Load a magnet and set the magnet zone to ONLY influence that new tounge-group.
I'm having some luck manipulatng with the morphbrush tool, but it's hard to get exactly the desired parts as the computer slows way down while selecting.
With magnets I selected tongue (the new group) in the group for mag zone properties. The magnet still doesn't change the tongue. In magnet properties the new group "tongue" isn't available in the "add elements to deform" sub menu.
It seems like magnet would be easier, but it still won't effect the tongue.
"...and assigned the material (tongue.)"
Hmm, don't assign the tounge material.
Use it only to select the tounge mesh, but then assign a "New Material" to make the new group permanent.
This will give the tounge a garish color, but once you have finished your morph, export it as an object and use it with a copy of your original Hiro.
Also move the magnet zone around and/or rescale it.
There is no need to add the new group to the magnet itself, that's why Poser doesn't give you that option.
As long as it's added to the magnet zone and it is inside the magnet zone, you can deform it with the mag.
Hmm, how many "undo's" have you set in your general preferences ?
These eat up a lot of money.
Set them to 3 to 5, as the morphbrush needs all the RAM it can get to work on hirez figures like Hiro.
Redo was set to 100. Turning it down made a huge difference.
With the new material assigned to the tongue it turns blue, but it does work better (maybe it's just redo set lower) for the morphbrush tool. Is there a way to select certain parts of the tongue, because when I pull or push with the morphbrush it selects other parts of the face during the process.
The mag still has no effect. As soon as the zone is expanded to touch any part of the face, it warps, but while only the tongue is in the zone nothing happens.
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2726915
If your magnet deforms both the head and the tounge, something must have gone wrong while making the new tounge group or selecting the new group for the magnet zone,This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I'm trying to get Hiro's tongue to curve down. Magnets have had no effect on the tongue, which is the way I thought it would be done. With the magnet base under or on the tongue, and the zone around the tip, moving the magnet does nothing.
There are tongue morphs for Hiro but I don't want to spend money if not necessary. If the magnet doesn't work on the tongue, then how is a pose set for the tongue made?
