Fri, Dec 27, 5:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Poser and ATI 7.12 Drivers
Magnatude ( ) posted Sun, 13 January 2008 at 10:33 PM · edited Thu, 26 December 2024 at 2:02 PM
Anyone else having a problem with the new ATI Radeon Drivers? version 7.12
Problems I've been having is a huge amount of lag. I mean HUGE.
I switched back to version 7.10 and the lag stopped. So anyone encountering this, take note!
(I'm using an ATI X1600 Pro 512, and 2 gig DDR for memory and Poser 4/5/6)
Carrara 7 Pro, Anime Studio Pro 8, Hexagon 2.5, Zbrush 4.6, trueSpace 7.6, and Corel Draw X3. Manga Studio 4EX, Open Canvas 5, WACOM Cintiq 12WX User
CuriousGeorge ( ) posted Mon, 14 January 2008 at 12:05 AM
Thanks man, I have the exact same card as you and I was just thinking of upgrading my drivers!
Regards,
                    George
Darboshanski ( ) posted Mon, 14 January 2008 at 7:47 AM
I don't have an ATI card but had similar problems with the last Nvidia drivers. Man, updated drivers lately have been the pits when it comes to using poser.
My Facebook Page
miken999 ( ) posted Mon, 14 January 2008 at 10:32 AM
I'm back as well on 7.10, unable to use Poser 7 in OpenGL Mode with Catalyst 7.12.
With 7.12 Poser 7 is unusable in OpenGL : Slow down, freezes or crash.
Gareee ( ) posted Mon, 14 January 2008 at 11:24 AM
Evidently ATI is incorporating some of the driver issues from Vista to XP now. I contacted Uli at EF about it last month.
Use the 7.12 drivers, and in the poser ini in the documents applications folder make this change:
Here are the steps in a nutshell:
"Windows Vista owners with certain ATI graphics cards may notice that
Poser takes a long time to highlight the body part or prop that is moused
over (due to the long delay it may appear that items are not highlighting
at all.) This complicates the job of selecting parts to pose; the
situation can be greatly improved by editing the Poser.ini file to set the
PREVIEW_OGL_OBJECT_BBOXPICKING entry to 1 (from the default zero.)"
That resolved the issue here with the 7.12 drivers. I always update my drivers as soon as they are available, and ran into this weeks ago.. it drove me NUTS trying to figure out what was what, but fortunately, I had a poser guru I could ask about it.
So, install the 7.12 ati driver, reboot, and then make the ini change before starting poser up.. I didn't see any issues at all with P7 after that change.
Magnatude ( ) posted Mon, 14 January 2008 at 11:41 AM
Thanks I will try that later today, I'm still using old XP, Vista still scares me.
msg24_7 ( ) posted Mon, 14 January 2008 at 12:31 PM
I am using XP SP2 as well.... had the same problem with the 7.12 driver.
The tip posted by Gareee solved the problem.
No more lag when selecting items or moving/rotating the camera or when working
in the material room.
Thanks for posting!
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
Gareee ( ) posted Mon, 14 January 2008 at 2:07 PM
My pleasure! I usually HAVE to upgrade drivers, because either a new game or a 3d utility HAS to have the latest ones installed.
I reported the issue to EF as soon as I saw theissue, and evidenty they've been working closely with ATI in resolving various issues, and this one was in a database of vista fixes.
Sounds like it's more ATI's fault then anything else, but I personally don't care whose fault it is, so long as there's a cure.
Magnatude ( ) posted Mon, 21 January 2008 at 3:55 PM
What about Poser 6?
I dont see this in my ini.
I have the following:
BOUNDING_BOXES 1
DEPTH_CUE 0
SHOW_LIGHTS 0
DRAW_OFFSCREEN 1
BEND_BODY_PARTS 1
HILITE_BODY_PART 1
BACKFACE_CULL 0
BACKGROUND_COLOR 36044 34047 32767
FOREGROUND_COLOR 56319 56319 56319
UI_BACKGROUND_COLOR 54227 51143 47288
UI_BACKGROUND_IMAGE 0
MODE_PALETTE_LOC 475 86
LIBRARY_PALETTE_LOC 646 86
LIBRARY_PALETTE_ON 0
PARM_DIALS_ON 1
ANIM_PALETTE_LOC 7 450
ANIM_PALETTE_ON 0
ANIM_PALETTE_SIZE 607 373
STATUS_BAR_LOC 426 375
JOINT_TWEAK_LOC 35 104
QUATERNION_ON 0
USE_META_UI 1
LAUNCH_PREFERRED 0
UI_PREVIOUS 1
GRAPH_PALETTE_LOC 472 465
GRAPH_PALETTE_SIZE 560 240
GROUP_PALETTE_LOC 7 508
GENITALS_ON 0
FIRST_TIME_CP 1
HIER_EDITOR_LOC 30 45
HIER_EDITOR_SIZE 521 659
PYTHON_PALETTE_LOC 960 81
PYTHON_EDITOR_PATH ""
USE_COMPRESSION 0
MTS_BROADCAST_KEY "Enter Broadcast Key URL here"
HTML_WINDOW_LOC 174 165 865 633
HTML_WINDOW_ON 0
UNIT_SCALE_FACTOR 8.600000
DEFAULT_CREASE_ANGLE 80.000000
UNIT_SCALE_TYPE 2
ALLOW_ANIM_LAYERS 0
AUTO_OPEN_MTL_LIBS 0
FACE_ROOM_HQ_TEXTURE_WIDTH 512
FACE_ROOM_HQ_TEXTURE_HEIGHT 512
DOC_TOOLS_ON 1
ENABLE_MTS_STREAMING 0
USE_OPENGL 1
OGL_SOFTWARE_ACCUM_BUFFER 1
KEEP_TEXTURES_LOADED 0
USE_EXTERNAL_BINARYMORPH 1
USE_P5CLOTH_DYNFMT 0
WRITE_FILE_SEARCH_LOG 0
MTL_VIEW_SIMPLE_ADVANCED 0
CACHED_RENDERS_MAX 10
CHECK_FOR_UPDATES_ON_LAUNCH 1
CHECK_FOR_UPDATES_COUNT 2
OBEY_ORIGINAL_NORMALS 0
PORT_SETTING 1517
MEM_AVAIL_MINIMUM 33554432
AUTO_RESIZE_BUCKETS 1
BUCKET_RESIZE_PCT 0.375000
LAST_OPEN_SAVE_PATH "C:Program FilesCurious LabsPoser 6New ObjectsZeta"
WRITE_MEMORY_LOG 0
FIGURE_CIRCLE 1
TABLET_MODE 0
Gareee ( ) posted Mon, 21 January 2008 at 4:01 PM
Might be a new issues with p6.. did you install the new jan 08 driver?
Magnatude ( ) posted Mon, 21 January 2008 at 5:34 PM
Oh, ok, the 8.1 driver is out now.
Seems to work fine with 8.1
Gareee ( ) posted Mon, 21 January 2008 at 8:36 PM
musta been a bug in the 7-12's
magne ( ) posted Mon, 11 February 2008 at 10:36 PM
I updated to 8.1 from 7.11 and I got this problem now on a 1600pro and got this problem.
It's a huge lag then I change from an object to camera or try use the material editor. Strangely moving the cameras work great but not to change cameras.
Will try to go back to 7.11 and see if it helps.
