Mon, Jan 27, 3:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: White gold ring
mystmaiden ( ) posted Mon, 14 January 2008 at 8:17 PM · edited Mon, 27 January 2025 at 3:56 PM
Would anyone happen to know where I might find a white gold ring (with no stones)  for M3, I've searched but I don't seem to be finding anything..
Just thought someone here might know off hand.
Thanks
myst
SamTherapy ( ) posted Mon, 14 January 2008 at 9:19 PM
Flatten a torus and add an appropriate material to it.  Dead easy.
mystmaiden ( ) posted Mon, 14 January 2008 at 11:06 PM
Thanks SamTherapy, now, and here's where I show my ignorance.. what's a torus and where does one find one?
blushing bright crimson -
myst
nickedshield ( ) posted Mon, 14 January 2008 at 11:08 PM
It be in the Props folder, Primitives I believe, depending on your version of Poser.
Acadia ( ) posted Mon, 14 January 2008 at 11:40 PM
Here are some ready made rings that you can apply a chrome material to.  They aren't for M3, but you can resize them and then go to "Object" and "Change Parent" and parent it to the finger.
http://www.renderosity.com/mod/freestuff/index.php?user_id=121705
http://www.rocky3d.com/jewelry.htm
mystmaiden ( ) posted Tue, 15 January 2008 at 12:05 PM · edited Tue, 15 January 2008 at 12:07 PM
Thank you all so much! I did try doing a ring with the torus in primitives, so far no luck. I got it to look like I wanted but not to fit onto his finger correctly. Definitely worth trying again.  I'll use one of the free rings Acadia listed.  I've always wanted to do a project made up of images of characters from my favourite series of books and the white gold ring is important for that.
myst
nickedshield ( ) posted Tue, 15 January 2008 at 12:43 PM
One thing about getting the torus to fit, use magnets to shape it. Something to play with when you get the time and inclination.
svdl ( ) posted Tue, 15 January 2008 at 3:08 PM
You'll probably also need a way to remove the ring finger and pinky of the right hand of M3 - if my guess of your favorite series is right.
Here's how you do that:
  • select rPinky1 and set its Taper value to 100%
  • select rPinky2 and set its Scale value to 0%
  • select rPinky3 and set its Scale value to 0% and Visible to false
Same for rRing1,rRing2,rRing3.
My gallery   My freestuff
mystmaiden ( ) posted Wed, 16 January 2008 at 6:32 AM · edited Wed, 16 January 2008 at 6:34 AM
**svdl,
Oh! You're 100% right! Thanks soo much for the pointer, I'll need that, looking at what you have there, what I planned wouldn't have worked.
And nickedshield, thank you, I hadn't thought of magnets, I've never messed with them and I really Should learn, seems like they'd be handy.
myst
