Tue, Nov 26, 6:40 PM CST
Subject: Wall Lighting
ColdWarTendencies ( ) posted Mon, 14 January 2008 at 11:41 PM · edited Tue, 26 November 2024 at 6:31 PM
I hope this is in right forum:
A friend bought me a copy of Poser 7 for X-Mas , I really have no clue on it's use , Maybe I'm jumping in at the deep end , My ai*m is to create a flickering light on the right hand wall , I can't even create a decent room hah , Below is an image done in PsP to indicate (Hopefully) a sort of Hallway , Wall lighting on right hand side.
 Would this be easier using PsP or is poser usefull for such a task ?
 Sorry for being so vague , Sleepless Night's later , Thanks for any input suggestions!
coocooFORcocoapuffs ( ) posted Tue, 15 January 2008 at 12:54 AM
I'm no expert, but you are in the right place I think. If putting up walls with windows is too much, there are lots of free or lowcost environments and props that u can add to any figure scene. good luck!
ColdWarTendencies ( ) posted Tue, 15 January 2008 at 4:53 AM
Thank you for your response **coocooFORcocoapuffs
I kinda got affect I was after & found a hallway (Kindest regards to TrekkieGrrrl)
Um not sure how it looks but a quick preview =
Supposed to be a Warning Emergency light situation thingy
Will keep playing & see how I gets on
(When I turn light on & off it doesn't work in animation in poser , why is this ? Pasted into animation shop)
coocooFORcocoapuffs ( ) posted Tue, 15 January 2008 at 6:28 AM
hey that's pretty cool. try using the built-in in poses for your figure so he looks a bit more natural, and ur stock library should also have some hair, unless u want him to look like me....but u are well on ur way to becoming a poser expert...sorry cant help ya with animation, i just use poser for stills right now, but someone here is sure to give u advice!
ColdWarTendencies ( ) posted Tue, 15 January 2008 at 6:53 AM
"Unless You Want Him To Look Like me"
Hah hah
Nah before I concentrate on the character I want to get the lighting etc. right , No point in spending hours on texturing making character up , Infact maybe I should start with the basics heh , Thanking you again coocooFORcocoapuffs for your input , I'll check out your gallery , Me is not much of a Poser person atm :D
pakled ( ) posted Tue, 15 January 2008 at 7:09 AM
every one of us were where you are once...;) hey, at least you've tried animation, which I've never done...;)
coocooFORcocoapuffs ( ) posted Tue, 15 January 2008 at 7:36 AM
Attached Link: http://www.phoenixstudios.com.np/Zoomify.html
> Quote - "Unless You Want Him To Look Like me" > Hah hah > Nah before I concentrate on the character I want to get the lighting etc. right , No point in spending hours on texturing making character up , Infact maybe I should start with the basics heh , Thanking you again **coocooFORcocoapuffs for your input , I'll check out your gallery , Me is not much of a Poser person atm :D**
your welcome! i am just learning lighting now, i am doing it backwards i guess. here is my latest work in poser/photoshop...if i ever get a sponser i will do the game for real and THEN have to learn poser animation:) http://www.phoenixstudios.com.np/Zoomify.html
geep ( ) posted Tue, 15 January 2008 at 12:27 PM
Hi ColdWarTendencies,
You can not animate the ON / OFF parameter to make a light blink but ...
You can use the "Intensity" parameter and change it from normal intensity (1,000) to 0.000 (OFF).
Use the "Break Spline" or linerar spline function to get a quick response from ON to OFF to ON.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Tguyus ( ) posted Wed, 16 January 2008 at 1:16 PM
Quote - You can use the "Intensity" parameter and change it from normal intensity (1,000) to 0.000 (OFF).
cheers,
dr geep
As usual, the famous Dr Geep has the answer.  Once you get a little facile with the animation palette, you might experiment with adding more keyframes (the existence of a keyframe in a given frame being denoted in the animation palette by the black cross along the spline... see Dr Geep's image).  Then if you play with assigning different keyframe types to various keyframes and adjusting the spacing between the "light on" and "light off" intensity parameter valies, you can change the timing and character of the light flashes.  For example, Dr Geep's appropriately straightforward, instant flash on / flash off could be modified to a slow (and even acccelerating or decelerating) fade in and/or fade out.  And if you want to get REALLY fancy at some point, you could use a python script using a parameter value randomizer (see Ockham's collection of python scripts) to easily make the light flicker even over a very long animation (i.e., instead of keyframing the intensity levels by hand).  Good luck, and have fun!
