which version of Vue, what operating system and do you have a screen print of the incorrect mapping. That'll help us figure out what went wrong
My Freebies
Buy stuff on RedBubble
Attached Link: Screenprint
This is a screenprint.There's only one mapped picture and it seems to be for the boat itself, not the sails.
But there's no way I can split the model so I can apply the texture on the boat only.
"Keep smiling, it makes people wonder what you're up to."
It's why I stick to .obj format! ;)
You could try exporting as .obj, with textures, and then UV mapping it, with UVmapper or some such? :)
alas, over the years I've had numerous such problems with .3ds, some are in old, crappy formats, not sure if the .3ds format varied (which it has), or the original program used ot make the models sucked.
Maybe 3DMAX or it's freebie verison could fix it, bar that or re-mapping, I'd alas, just bin them :/
my uvmapping tutorial :)
http://www.silverblades-suitcase.com/tutorials/htm/14.html
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
NPB :)
yeah the older the .3ds model is, higher risk of it being crap seems to be :/
"I'd rather be a
D&D items, stories.
Quote - Did you try changing mapping coordinates to object parametric? Most of the times, it does te job.
Yes, I've tried that too.
It simply won't matter what I do in Vue to make this work.
And I've decided to bin it. It's not worth the hassle.
C.
Actually, there's nothing wrong with the *.3ds file format or UV maps loaded into it - I prefer it for its universality and small file size. However, some model-builders and some modelling tools don't do a good job, particularly if they are attempting to create single "normal map" in which the model-builder trys to get every part of the model mapped out onto a single image file. The "normal map" ends up being poorly made, usually with overlapping polygons on the image, or other poor separations between the model's components, ... and the *.3ds file header ends up with an illogical set of coordinates for the UV mapping points. Some cheap UV mapping tools do this, and some UV mapping tools built into inexpensive modelling programs do this. But, this is a problem with the modeller and/or his choice of UV mapping tool - it is not a problem with the *.3ds file format. (Not to mention a brokering site or web site that allows posting of models without checking to see if they pass minimum quality standards.) Sorry if this is long-winded. I'm an admitted techie, and it just bugs me a bit when people blame a file format as a general rule and don't cut to the actual source of the problem. Looking at your image, I'd say that you have a model with exactly this kind of problem, although it is possible that the image file part of your package was damaged, rather than damage to the model itself. My guess is that you have a product made by an inexperienced model-builder who used an inexpensive modelling program with a built-in UV mapping function. The sailboat problem looks fine in his or her program, but not in anyone else's program. Since you've tossed the sailboat object, is it possible for you to post the exact URL linking to the source of your bad sailboat model? (There are a lot of uninedxed models on Archive3d.net. If you had not tossed it, I would have liked to have taken a look at it to see if I could examine the UV map itself, and possibly rectify it, or tell you for certain that its a "lost job." Sorry I didn't see your post earlier - was babysitting a sick grandson for a coupe of days. Respectfylly, Forester
Forester - I found 3 models that has a similar problem and as you just said, at least for the motorboat they squeezed in the entire texture - two sides and the top texture - on a small jpg.
I've tried these models without any luck.
http://archive3d.net/?a=download&id=13367
http://archive3d.net/?a=download&id=13366
http://archive3d.net/?a=download&id=13364
I never intended to use them for any closeups, so the detail in them are rather irrelevant, but I liked the way they looked. And the colors would still be visiable when the sun is shining on them, so I can't use them without it.
Thanks for your reply :)
Christa
Forester - thank you :)
I've used a lot of .3ds models, but I've never seen anything like this before. And yes, the texture files ended up looking as if someone closed their eyes and given them a file name on a keyboard from Star Trek or something.
But what you just told me explains a lot.
And they have all gone into the bin.
Thanks again for all your help :)
Christa
Quote - Actually, there's nothing wrong with the *.3ds file format or UV maps loaded into it - I prefer it for its universality and small file size. However, some model-builders and some modelling tools don't do a good job...
Poor modelers tend to use 3ds format. Better modelers tend to use obj format. The 3ds format already has enough problems of its own without end-users having to add to them.
I guess you'll have to count me as one of those "poor modelers" then. Pretty much all my models for commercial purposes are converted into that file format for both technical and practical reasons. Shonner, you're not really hurting my feelings, but you are damning a lot of us professionals, and this would either make us mad or make us think that this was a reasonably ignorant statement. However, I do not want to get into any kind of flame war - I hate those and so I'm ending my comments here. My intent was only to try to help croxie, and help anything having to do with sailboats.
Not all users of the 3ds format are poor modelers, though. But their models would be better if not triangulated.
See! Now that is the perfect example of a non-triangulated model.
Come to the polygon side, you will, young Jedi! :D
"I'd rather be a
D&D items, stories.
Pam,
Great posts, very informative, just like all your others. You add much to this community.
Shonner, you say:
"But their models would be better if not triangulated."
This is the Vue forum. You probably don't know, but Vue triangulates ALL models on import. Stay tuned and you'll learn something :-)
I believe that the 3ds object included in this yacht object zipfile was meant to be as an added (simple) convert. Since the zip includes a ".gsm" file, probably the construction and texturing was done in the special 3D CAD software called ArchiCAD.
Loading and using this yacht in ArchiCAD might be working perfect, together with the included textures - it just doesn't work right with the 3ds conversion.
To make it work, you would have to load this 3ds object into a modeler, take it apart (cutting out sails, boat top, boat side - whatever) and retexture it, maybe using the free UV-Mapper as an easy to use mapping tool.
But because it's someone elses model, this for sure would violate copyright laws ...
All good points. BTW, I did de-construct it into its component parts when I was examining it to see it would have been reasonable to try re-mapping it. But, whew! this model has got an awful lot of "parts" - about 125 of them. Not a reasonable use of time, given the relatively crude nature of the model. With, or without potential copyright violations.
I downloaded a couple of freebies from Archive3d.net yesterday, and most of the time when I import 3ds into Vue there's no problem with the texturing.
These boats (it is a sailing boat and a motorboat) I just can't figure out. I've tried the textures that came with them (pictures) but no matter what I do I can't get them to map correctly.
Since I'm not a modeler I'm dumb when it comes to these things.
Can someone please help? What do I do?
Christa
