When you import - you can check collapse identical materials. But if I'm reading you requirement correctly each figure will have to retain it's map. Since they are indeed separate items. The collapse works for example if you import V3 & the same material(map) is being for multiple body parts ie legs/arms/torso.
"then just drag the duplicated maps onto each other. Drag until you get down to 1."
I have absolutely no idea how to do that. I don't know how to show both maps at the same time, since they are on different characters/character-parts (objects) and I can only open one at a time in the function editor (as far as I know). I'd love to know how to do it:-)
NB - I'm on Vue 5 I, so that may be a Vue 6 thing..
Cheers,
Diolma
Hi all.
Does anyone know how V5I deals with duplicated texture maps?
In other words, if I have two or more characters sharing the same set of textures maps, does V5I load a separate copy of each texture for each character?
Or is it clever enough to realise that it already has that specific map in memory?
The reason I ask is 'cos I'm doing a scene with several characters, all of which share the same texture maps (although they are modified differently in the Function editor, but the base maps are the same for each character). I want to cram as many characters as I can into the scene, but if the maps aren't consolidated then I'm rapidly going to run out of memory and so will have to use function-only textures. It'd help me a lot to know in advance whether or not to load textures in Poser before saving the PZ3...
Cheers,
Diolma
