Tue, Jan 21, 9:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: Weird install message...
DocMatter ( ) posted Fri, 18 January 2008 at 10:51 AM · edited Tue, 21 January 2025 at 9:34 PM
I just installed Vista on my computer (after backing up everything).  I tried reinstalling Poser 6 and got this bizarre message that wouldn't let me install. What's up with this?  'Elevation?"
pdblake ( ) posted Fri, 18 January 2008 at 11:01 AM · edited Fri, 18 January 2008 at 11:02 AM
Attached Link: Linky
Maybe you need to stand on a box?
Seriously a quick google tells me that you need elevated priviledges. I presume that means you need to log on with administrator priviledges to install.
svdl ( ) posted Fri, 18 January 2008 at 12:12 PM
You could also browse the CD, right-click Setup.exe in the root folder of the CD and choose "Run as administrator" (or whatever it may be called in Vista. I don't run Vista).
My gallery   My freestuff
thefixer ( ) posted Fri, 18 January 2008 at 3:23 PM
Running as admin should fix that because Vista is telling you you don't have sufficient privileges to do what you're trying to do!
There are ways of switching off the UAC depending on what version of Vista you're running, which is it??
Injustice will be avenged.
Cofiwch Dryweryn.
DocMatter ( ) posted Fri, 18 January 2008 at 4:36 PM
I'm running Vista Ultimate.  I already figured out svdl's method accidentally and its all installed okay.
Thanks for everyone's help!
