Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Attached Link: AnimeDoll
motura, I'm not sure I know what your question is. The AnimeDoll figure itself is no longer listed in the Renderosity marketplace. AnimeDoll / Maya Doll are at StudioMaya's store: http://www.3digitalcrafts.net/studiomaya/1store/index.html Whatever3d search "AnimeDoll" for AD products: http://www.whatever3d.com/search.ez?q=AnimeDoll http://www.whatever3d.com/search.ez?q=MayaDoll bBMiss Nancy
Thank you.
I tried to exhibit the product in the market many times.
Trouble occurred to it in Poser of English version.
I got mail from Helen.
However, the trouble that Helen pointed out was every time different.
And, I am" above listed product cannot be resubmitted for the next 30 days due to numerous failed testing."
/(ToT)
Attached Link: http://www.csse.monash.edu.au/~jwb/cgi-bin/wwwjdic.cgi?9T
You could try this. It might help a little. (Kanji -> English)Motura: I've seen your product in the marketplace queue. What is probably happening is that your product is getting tested, and after you correct one item and resubmit, some other error is found.
What I would suggest is that you find yourself 2-3 beta testers for it that runs an english version of Poser, and have your product tested thoroughly by them, so by the time you submit to the marketplace, the problems with the version are ironed out.
Attached Link: Anime Doll
Anime Doll is listed in the Renderosity marketplace User MayaX which is a addon for the free Maya Doll by Studio Maya (who I assume is the same person) and Maya Doll is free on Studio Maya's site.Motura: you normally advertise yourself for them; there is a forum for beta testers offered in PoserPros. Check out here http://poserpros.daz3d.com/forums/viewforum.php?f=18 and see if anybody lists AD as one of the characters they work with. Failing that, one of my beta testers uses AD, I believe, so when I see him I will ask him if he's willing to work with you on that. But try the classified ads, or post a message in this forum asking for beta testers for your product.
Just make sure that the people who are testing for you are THOROUGH; there is a lot of people that will tell you they beta-test and will just load the item once, do a couple of poses and mark it as "good" when it might not be the case.
I don't speak japanese, but I've been a merchant for a while, so if I can be of any further assistance, send me a PM through here and I'll try to help :)
I can help with testing and I've worked with items made in the Japanese version of Poser before so I can find where it's hanging up in the English version and suggest solutions.
I don't have AD but I do have Mayadoll and as I understand things the difference is the head of the figure, so I can certainly test any item below that point.
Arien and darken666
Thank you very much.
I look for tester there.
I did not know this forum.
It did not teach even though mail was sent to Helen times how many.
I sent mail to Helen and the person in the market many times.
And, the tester was heard where it was necessary to look for.
However, she did not teach.
Helen and people in the market hate me. ......(/_;)
Even if they send one mail, they never give the answer.
When the same 50 mail is sent, it gives one answer.
Motura: which site? PoserPros? they will, if you used a freebie email account when you sign up. Email Gaurie ( storeadmin@poserpros.com ), he's the admin there; direct him to this thread and explain you are trying to find beta testers. You could also submit the set to their store, you know :)
Renderosity will reject a submission if you've failed three times, you can't resubmit within one month I think, and then you need to provide the names of two of your beta testers. Take the time to have the set tested by people using the English version of Poser, and make sure you also have an english speaker check the Readme, as Renderosity has very strict guidelines on what should be in the Readme and how.
I have Anime doll and Maya Doll and I've got all your freebies, too, Motura.
They're awesome and I'll be happy to help you test them.
すみません日本語はよくできません ^__^)'
The tester seems to be found by having written it here.
Thank you. m(_ _)m
Miss Nancy
The Chinese character exists about the file such as Cr2 to be deep … By not
finding even if I look for. (+_+;)
ldynghtwng
Thank you!
Cannot communications be taken by the emoticon?
(^^) (T_T) (^^)/ (^o^) (><) (--) <(_ )> (^^;)
(^3^) %(-_-)
Motura:
try http://www.renderosity.com/mod/freestuff/index.php?user_id=12815
There used to be something called "Poser Merchant Utility" but I can't find it. In the meantime, that list maker should help
I want to include the item of AD BOY in this products of "AD MANTAN SET".
AD BOY can be made AD BOY KIZ.
Help me (T_T)
Does nobody understand Japanese from the AD user?
