Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Ok, always be specific on tech problems, please, it helps :)
-Vue Inf 5 or 6? What build of patch?
-What operating system, computer details etc?
etc, much info as possible helps :)
ok, you wouldn't happen to have a Vista ot vista 64 bit system would you? In which case, try running Vue as ADMINISTRATOR.
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
Normally this behavior is related to wrong pathnames to the geometries (.obj) in the pz3 files. Something Poser does not care about because it has a built in search functionality but for Vue it s a problem. So check the pz3 files and maybe correct the pathnames to the geometry manually there. and then try again.
The problem becomes worse whe using non default Runtimes for better personal structures. But this is not the only issue, sometimes even the original pathnames in the cr2 etc files are wrong already and they are "copied" into a pz3 file simply instead that Poser writes the correct one again.
Attached Link: http://www.hogsoft.com/content/index.php?name=Content&pid=2
*For correct paths I use a free utility here called Correct Reference! * Apparently it's not here any more but you can get it from the link provided!Injustice will be avenged.
Cofiwch Dryweryn.
Okay, to go into more detail on my issue.
I am not that Poser-literate, so I am not sure if the geometries are messed up or not. I figured that I would, however, list some of the items in question in case someone else has had issues with them before..that would, of course, be an easy key to showing if they do have geometry issues. I am currently not in the money, so alas, I cannot pay for the Pro version.
No worries, happy to help!
You may need to do this quite oftem, especially if you add stuff to your runtime all the time like I do! [LOL].
I've got to the point where I run the script each time I put something new in my runtime, only takes a minute and saves any hassle later!!
Cofiwch Dryweryn.
Hello, I am a Vue Infinite user since late 2007, but I have just now started really integrating with Poser 7. So far, it has been excellent to the point of near perfection..save for one issue. Any scene I import lacks ALL smart props..now error message, no forewarning, no apparent reason. Are there any solutions to this annoying issue? It looks weird to have warrior poses with fists clenched around thin air.
