Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Hi drgntear71,
You might try this ...
Use the Grouping Tool (GT) to duplicate the GROUND prop ("Create Prop").
Include all of the polygons in the GROUND EXCEPT one (this makes a hole in the "New" GROUND "prop").
Now, you can use a magnet or other (external modeling program) to modify your new prop to suit your needs.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
This sounds like a job for Displacement-man. Now you don't have to worry at all about polygon counts on the ground plane and can even animate the vortex if desired. You will probably not get a direct visual in the Document window but smallish renders should prove useful.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
have you tried jointing a couplie of tourus' and streatching and twisting/rotating them? (G'day doc)
I know in Wings3d if you have them appart a bit and then having the bottom all one face(delete lines + verts) then bridge the opposing faces you can get some cool effects, particularly if the objects are off center from each other. dunno if Poser has an equivinlent??
Jen.
Or, find a skirt with a 'swirl' or 'twist' morph, give it the same texture as
the ground, put it around your figure, and extend the skirt down
until it goes through the ground.
My python page
My ShareCG freebies
Don't ask me. I don't know my warp from a a hole in the ground. :biggrin:
Attached Link: A hole in the ground
Its too cold to shovel snow, so I dug a hole in the poser ground instead!( Actually, its a completely different mesh)
You were going to say 'bellybutton', correct?! :tongue1:
off.
-- Bjarne
Stroustrup
I am looking for help on creating a vortes or warp hole from the ground. I am trying to show a spirt or zombie coming from the ground or object and do not know how to do it. I want it to be stretced and tapered down from the waist in to this vortex. If any body has any info pleas let me know. I am using poser 7 and i have tried the magnet but i do not get the results i am looking for.
Thank You
Shawn
