Sat, Feb 8, 9:51 AM CST
Subject: Poser for windows vista
mdiramali ( ) posted Fri, 25 January 2008 at 5:31 AM · edited Sat, 08 February 2025 at 9:46 AM
Does poser 6 or 7 work with windows vista?
Stepdad ( ) posted Fri, 25 January 2008 at 5:44 AM
I know for certain 7 does, in fact it's been more stable for me under Vista than it was under XP.  I can't imagine why 6 wouldn't, in fact I haven't had trouble with any of the apps I used to run under XP with Vista.
Now, a word of caution, not everyone has had such luck with Vista, it can be a bit finicky about the hardware your using and if you don't at meet or exceed it's minimum system requirements you might want to reconsider installing it.
Also as with any windows based operating system, your best bet is to wipe a partition and do a clean install, trying to install over a different version of windows all too often results in problems, particularly in the stability area.
So if you are going to give Vista a look you'll want to backup your files and do a clean install for best results.  Personally I'm very happy with it, but mileage does vary - a lot of other folks were not happy with it when they installed it.
Hope that helps..
Stepdad
pakled ( ) posted Fri, 25 January 2008 at 6:54 AM
syntax error: 'Vista' and 'working' used in same sentance. Redo from start, and call Dr. Watson in the morning...;)
thefixer ( ) posted Fri, 25 January 2008 at 8:42 AM
Yes it does, I'm running Poser 6 and 7 on Vista Ultimate 64, no issues!
Injustice will be avenged.
Cofiwch Dryweryn.
mandy2uk ( ) posted Fri, 25 January 2008 at 8:53 AM
Quote - Does poser 6 or 7 work with windows vista?
I'm running Vista and Poser 7 is working for me without any problems!
Ondoval ( ) posted Fri, 25 January 2008 at 11:14 AM
poser 7 + Vista 32 (3Go Ram)
Very stable for me.
For art to exist, for any sort of aesthetic activity to exist, a certain physiological precondition is indispensable: intoxication.
We have art in order not to die of the truth.
Friedrich Nietzsche
Santel ( ) posted Fri, 25 January 2008 at 11:36 AM
Both 6 & 7 fine for me as well...
silverblade33 ( ) posted Fri, 25 January 2008 at 12:53 PM
P6 works great on my Vista 64 :) loads lot faster
Cage ( ) posted Sat, 26 January 2008 at 12:04 AM
Poser 5 and Poser 7 are both handling well for me on Vista.  I wish I could say that about all of my other frequent use applications....
