Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 3:25 am)
See this thread for starters:
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Hi all, I've just finished an animation for my character (nothing fancy, but I've spent some time and finally i like it). Basically I created a base layer with a walk, then corrected/exagerated some of the moves thru another layer on top, and then added another layer with some more stuff...
When the pose is saved (as an animation) to the library it looks like it only saves the selected layer. I only get the corrections saved if I'm in layer 1, or only the walk if I'm in base layer... Is it possible to bake/merge/collapse the 3 layers into one, so the whole animation gets saved to the library?
My goal is to render all the stuff in Carrara, and it turns out that when importing the whole scene the animation doesn't quite work as is supposed to... Not even when importing into DAZstudio! Only way I can think of, is collapsing the layers and importing the whole animation this way into Carrara. Any help??
Thanks!
