Fri, Nov 15, 11:42 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Another pivot point / Hot point question
Ulv ( ) posted Tue, 29 January 2008 at 5:40 AM · edited Fri, 15 November 2024 at 11:20 AM
Thanks to Mark Bremmer for the answer about Hexagon Pivot points not transferring while saving to .car file....
But is there anyway to set the hot point / rotation point to an object in Carrara by snapping to a point?  (rather then manually moving the hot point with CAPS lock, or by numerical input)
Thanks
Ulven
MarkBremmer ( ) posted Tue, 29 January 2008 at 8:48 AM · edited Tue, 29 January 2008 at 8:52 AM
 No, unfortunately. That is a feature found in most modeling programs. However, the Carrara assembly room is not a modeling area so I guess that it has avoided some of those "nice-eties". I think I'll head over to the DAZ site and make a request though. Can't believe it hadn't occured to me before.
Not that this helps, but on the Mac you can get the point to snap to the grid by holding down the Control key AFTER you start clicking and dragging.
Ulv ( ) posted Tue, 29 January 2008 at 9:34 AM
Thanks for the info Mark.
Holding Control also works on PC by they way for snapping to the grid, but you are, right it does not help in this instance.
Best of luck with Daz.
Ulven
