Tue, Jan 28, 5:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Anton's poseable ponytail
mickey2 ( ) posted Sun, 10 June 2001 at 11:06 AM · edited Sat, 03 August 2024 at 3:37 AM
Hi gang , what's up with this hair, I have tried it on every model from vickie to vick 2, to VV and it comes in side ways with no rotate control, and when I conform it ,it goes to the middle of the back and just sits there. Help
nitreug ( ) posted Sun, 10 June 2001 at 11:57 AM
I bought it yesterday but did not try it yet. The previous one need to be tweaked a bit to go on the head. Anton should had fixed it...but....!!!!????
Dagon ( ) posted Sun, 10 June 2001 at 12:05 PM
Load your character, Vicky or Posette, in default position Add the Ponytail hair, and move it to fit the girl's head Parent the hair figure to the character's head and lock it
RealitysPoison ( ) posted Sun, 10 June 2001 at 12:48 PM
I have noticed that on V2, the hair comes into exact placement. On the others, it only takes a bit of tweaking. Anton explained to me that it is because of the position Vicky starts in. Here are his words, hope he won't mind "The hair loads in to match Vicki in her"zero" position. Daz's cr2 brings her in a pose. Just turn of the Ik for her feet and open the joint Editor. Click 'zero figure' and then make sure the hip and body are zero. This is Vicki's true default pose." Give me two minutes to load a project file up, and I will give you the settings I used to fit it to V2P4
nitreug ( ) posted Sun, 10 June 2001 at 12:54 PM
Great work from Anton. I just went to see the 10 different shapes. Fantastic hair. Thanks Anton.
melanie ( ) posted Sun, 10 June 2001 at 6:09 PM
I love this hair, but I can't figure out how to get the ringlets on the updated version. Anyone know what setting does this? Melanie
PheonixRising ( ) posted Fri, 15 June 2001 at 3:35 AM
Thanks guys for the head-up. Vicki's hip has to be completely zeroed. Check the "y Trans". It is usually never at zero. The "base" is the main part oof the hair. Use that to move and rotate. The hair isn't intended to conform because it has differnt body parts that Vicki. Email me if you need to. Take care, Anton
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
