Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
I have noticed that on V2, the hair comes into exact placement. On the others, it only takes a bit of tweaking. Anton explained to me that it is because of the position Vicky starts in. Here are his words, hope he won't mind "The hair loads in to match Vicki in her"zero" position. Daz's cr2 brings her in a pose. Just turn of the Ik for her feet and open the joint Editor. Click 'zero figure' and then make sure the hip and body are zero. This is Vicki's true default pose." Give me two minutes to load a project file up, and I will give you the settings I used to fit it to V2P4
Thanks guys for the head-up. Vicki's hip has to be completely zeroed. Check the "y Trans". It is usually never at zero. The "base" is the main part oof the hair. Use that to move and rotate. The hair isn't intended to conform because it has differnt body parts that Vicki. Email me if you need to. Take care, Anton
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Hi gang , what's up with this hair, I have tried it on every model from vickie to vick 2, to VV and it comes in side ways with no rotate control, and when I conform it ,it goes to the middle of the back and just sits there. Help
