Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
BWTR --
Those are the tracking controls -- they move the camera through 3d space. The pan control is obtained by clicking on the dolly control (the round ball with the four arrows), which then changes to be a pan control and clicking it again makes it a "bank" control. The difference between panning and tracking is that a pan is a camera move that keeps the camera located in one place but turns it so it shows a different view, whereas a tracking shot moves the camera through space to get a different perspective.
Each technique has a place in motion picture production, but they're not interchangeable.
Patrick --
Thanks for the keyboard right-mouse-button tip; I hadn't seen that before.
:D
The "Pan" tool -- pictured on the right -- behaves exactly backwards of how it did in earlier versions. If you select the PAN tool and move your mouse to the right, the image pans to the left -- precisely the opposite of how it did before.
The right-button solution that our Teutonic friend above suggested, though, works as I expect the pan tool to work, as the pan tool has worked for years in Carrara.
And, yes, I'm using C6.03Pro.
Hi, all --
I've been using C6P for a couple weeks now and am really frustrated by the fact that they've reversed the pan tool -- what used to make the camera pan left now makes it pan right. Down is up, etc. It's really awkward.
I've looked through the forums and can't find an answer, so I'm asking. Is there a way to return the Pan tool to its previous orientation?
Or, am I stuck with the change? I'm reminded of Dr. McCoy's line in Star Trek: The Motion Picture. "I know engineers. They LOVE to change things!"
- Dex
