It might help those not familier with your subject to explain what it is? I've never heard of a 'Voronoi'...........;-)
Analitical geometry - simple ? ? O.K. - - - either you have a Masters in math or . . .[
http://www.voronoi.com/applications.htm](http://www.voronoi.com/applications.htm)
might get some up to speed.
It's too early in the morning for me. I'm still trying to wrap my mind around getting the percent of error in chaining a bunch of flat terrains into a circle figuring the total length as oppsed to the length of a true circle of the same circumferance.
simple ? ?
"Bryce's Voronoi noise functions ..."*
*O K...now I'm intrigued...how would one access this in the DTE my friend...does it have a name or something..I still find the DTE a wee bit confusing.. ,,,
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Friends don't let friends use booleans.
Too cool...another trick I didn't know/couldn't remember if i ever did...thanx a bunch pal.. off to play around...answers Zemela's query quite well as well.. ...
Once
I see
a sound
and
Sometimes
Attached Link: Robin Wood's Tutorials
I love the DTE - if you don't know what you're doing in there - it's still possible to have fun just playing with the "randomise" buttons, but if you want to know more you might try Robin Wood's Tutorials on Bryce.Click on "Intermediate Bryce Course" in the menu on the left, and scroll down to "Lesson 3: Demystifying the DTE"
I loved that one.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Quote - Analitical geometry - simple ? ? O.K. - - - either you have a Masters in math or . . .[
simple ? ?
Huh??? It's late in the day and too late for me to be confused... What the heck are you babbling about, my dear??? Did they slip a liquid lobotomy in your coffee this morning?
Just color me...
:b_confused:
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Can't help but get the feeling that someone just removed my bain.
Once
I see
a sound
and
Sometimes
OMG!!!! I've almost finished writing that novel too.
How is the old git? Tell him to write, will you, Bobby. I haven't heard from Paul for years.
Bain = Brain without the coffee.
LOL...thought that'd perk yer coffee...we're pals on msn which is where we chat...if you don't mind next time I'm there I'll send you an invite and get y on my buddy list. He's in Finland so the times I run into him you should be awake as well I figger.. ...
Once
I see
a sound
and
Sometimes
Boofy: A series of 3 sci-fi novels. The one above is #2.
Bobby: I knew he was in Finland. He used to live just down the road from me. Paul got me into 3d stuff.
Quote - well,thank you for your time,special thanks to dvlenk6 for the hint,.. I suppose I'd ask the 3DSMAx guys...
You didn't say you had 3ds max at your disposal.
Try this:
Displace (modifier) a plane of sufficient number of length and width segments. Use a 'Cellular' map in the Map slot of the displacement. If you need to, you can copy the map (or drag it) into a 'dumby material' (one that isn't being used for any objects) map slot, so that you can adjust the cellular noise parameters.
After you displace the plane, leave the modifier stack uncollapsed; and add a lattice modifier to the top of the stack: 'struts only'; 'ignore hidden edges' and 'end caps' checked. Adjust strut radius as needed.
Is that anything like what you need?
EDIT- if it still seems too regular, put a noise modifier before the displacement, or use another seperate displacement modifier. That will jiggle the vertices around so the the lines aren't perfect squares when viewed from straight above or below.
Bobby: Isn't there a TOS regarding gobbledegook like wot dvlenk6 just spouted?
*It's a TOS violation to try to help somebody?
*Of course not!
You have read 'Heresy and My Struggle Against It' by Cardinal Fang & Cardinal Point, available at all good books stores price £9.99, haven't you?
Hi all,
I have to create a Voronoi model, tryed some consructions, but hell it's extreme time consuming and kinda seems not the right way. Somebody here has expirience or ideas how to do it?
