Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
320gb hdd
4gb ram
nvidia geforce 8600 Gt 256mb GDDR2 dedicated graphics memory '
XP home
Thanks guys in advance.
Boofy, you can change the size of your working area by going to doc setup in your menu and choose the size. I usually choose 'max size allowed' and then change to something bigger when I am ready to render.
I'm not sure about your connection to Daz..but are you choosing the 'daz' button on the right top corner, above your work area, to go to daz? I believe it has to be in 'create' mode to see the button...it's a big button.
EDIT: It's the button on your first figure in your post...top right side round button green and white..last icon showing.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
There was an update to Bryce 6.1.13.1 6 that came from a DAZ email. If you reloaded Bryce maybe you missed this.
Go to DAZ
Click on the My Account link on the top right.
Type your email and password
Under My Account click on the Itemized Order History.
Look for your Bryce and studio updates and click on the right column that says Request Download Reset. Go to your shopping cart and reload the updates. Save them to a disk and put them in your Bryce case rather than just running them.
Hey thanks all you lot.
@AnnieD: but are you choosing the 'daz' button on the right top corner, above your work area, to go to daz? I believe it has to be in 'create' mode to see the button...it's a big button.
Yeah that is the one I used, bit hard to miss isn't it!
i will follow all the hints and tips when I get home and report the results. have a great day. Jen
In Bryce......Looks like you pulled away from the scene AFTER it rendered. Try going to the little + & - icons on the bottom right side bar and clicking the + icon to bring the render up to full workspace size.
Nope! thats how it loaded Bryster, but I tried the other suggestions and changing the Document size and saving it seemed to work.
Hmmm, nothing there about updates Electroglyph, just the normal downloads. Thanks for the tip but I guess I will have to keep hunting.
Do you need the update? The "Abour Bryce" screen from the Bryce help menu says Bryce 6, not the version number.
To check which version you have find your Bryce.exe file. It should be in C:Program FilesDAZBryce 6. Put your mouse over the file and a box with the version number should appear. If you right click on the folder and select properties you can also get this information.
I have version 6.1.13.1 and I think that's the latest.
