Hi, EnglishBob.
I think you are great user.
(I downloaded your Freestuff a lot.)
Thank you about your help.
But, your answer is different.
I used poser 7.
And it has 'Toon Render' option.
I think you use poser 4 with propack.
Ofcourse, Poser 4 is good program.
But it is different a little with Poser 7.
Sorry and thank you.
Attached Link: Some example shaders
Which shader do you use? I think, the shader is wrong - you need a cartoon shader for that. the upper picture looks right, the lower not - is it the same shader?Toon renders are done with the materials. They render like any other render.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Thank you about replies.
Deer bantha
I did not use a separate shader.
I mean the shader like below image.
www.bokgi.net/test/005.jpg
You can see arrow in above image.
And below two image is same.
www.bokgi.net/test/003.jpg
www.bokgi.net/test/004.jpg
Deer ezuk
I don't want out line.
Because, out line of poser is too thick.
It is not beautiful.
And Poser can support toon without out line.
Deer Miss Nancy
And I applied diffuse channel (at top of channel list)
Then the result is like below image.
www.bokgi.net/test/006.jpg
I want to know can I make movie by Toon Render.
(It is mean like below image that Toon Render.
www.bokgi.net/test/005.jpg)
Can you help me?
I do not know why the body fails to render as toon, unless your render settings are wrong
and your movie settings do not use your render settings. post a screen image of
your render settings and your movie settings.
Deer Miss Nancy
I offer you my heartfelt thanks about your reply.
Most of all, your idea is very good about outline problem.
I didn't think the way like that.
And, I applyed the material successfuly in material room.
It look good. (below image)
www.bokgi.net/test/007.jpg
But, movie is different.
The movie does not apply toon render.
www.bokgi.net/test/003.avi
Is it impossible of attainment?
smalll, it is possible of attainment.
7.swf
but it is necessary to set render settings at (firefly, final)
and to set movie settings to render settings. in your movie
you have used preview renderer, not firefly renderer.
(xposted with ezuk).
It is impossible making movie by Toon Render?
You know Toon Renders.
I did it.
You can see below image.
And I made it movie.
www.bokgi.net/test/000.avi
But, movie does not have Toon Render mode.
Plese teach me.
