Forum Moderators: Wolfenshire, Deenamic Forum Coordinators: Anim8dtoon
Photoshop F.A.Q (Last Updated: 2024 Sep 19 10:49 pm)
OK...when you add type in PS7 it's vector type so to enlarge it go to, Edit>Transform>Scale and a bounding box will appear around your type. When you've got it to the size you want hit Enter. As long as it stays in this vector format you can resize with zero distortion/artifating, but to work with filters or any of PS7's cool tools you have to Rasterize the type. Do this by going, Layer>Rasterize>Type..
Hope this helps.. ...
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Lucie
finfond.net
finfond.net
(store)
In full blown Photoshop you do as Bobbystahr says - you can also hit Ctrl+T to just bring up the Free Transform ability to resize. You shouldn't be able to just grab a corner, drag and it resizes - it's a command function.
In elements you can grab a corner at any time and drag to resize (very annoying - this should be a command function as you could do it accidentally all the time!).
hope this helps-
-Lew ;-)
@ Lucie...but if you "If you select the move tool and check "show bounding box" the bounding box will appear every time", it does limit you to those 3 of the many tools available...even after Rasterizing the layer, at least in PS7 which is what avalonfaayre said she uses.. ...
Once
I see
a sound
and
Sometimes
Yes Bobby, you're right, but she's just talking about strectching or resizing which she says she used to be able to do before (without needing to go to "Edit/transform" it seems) so I'm sort of wild guessing that maybe she used to have that "show bounding box" checked and she unchecked it without noticing...
Lucie
finfond.net
finfond.net
(store)
I used to be able to drag and drop from one image to another and then resize the image I dragged with the corner drag of the mouse. It used to work on the text as well. When I clicked on the layer, I could stretch the text. I can't do it any more! What did I do to change it, and how can I fix it?
