Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 30 3:32 am)
I've seen it happen sometimes but not often. Try moving the figure by the Hip, not Body.
Um, sorry Paul ... but I believe you have it backwards ... if the hip is moved and not the body, then when the figure's body is rotated, it will revolve around the original (unmoved body) position.
Move the body ... not the hip ... when moving a figure to a new location.
Now you can rotate the body in it's new location using either body or hip.
Use the hip for making poses.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Yes, Geep is right, implement xTran or zTran in the 'Body' not the hip. Implement yTran in the hip. The Body is an invisible actor that the hip is parented to. If you translate the hip away from the Body, then yRotate the Body, the Body will still be in its original location, so of course the hip is going to orbit it.
Attached Link: http://drgeep.com/p4/figcir/figcir.htm
*(click the image to view full size) (click the link above the image to view the complate tutorial - 7 pages)*This tutoeial might help explain things.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
If i move a character away from their original point when they are created by Poser 7 and place them in a scene...when I try to rotate them, they move around the original axis from where they were created.
Can I reset the axis point to the position where I have just moved them too?
I hope I explained that one OK.
Thank you all.
