is a DVD ..not a CD
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
What BAR-CODE said. There's more content than what would normally fit on a CD.
Might be a good excuse to upgrade. Besides, decent DVD drives (and with burners too!) aren't terribly expensive. (Should be able to find one under $50.)
Yeah! I'm sort of mad plus embarrassed that I skipped over the portion stating it was a DVD, I just checked out the .objs and Carrara requirements and a general scan of troubleshooting the disk didn't notice anything indicting new format. Normally insert the puppy extract what I want then scan the mag, pick out what interests me first etc. Just ASSumed that it was like all the prior disks. Feel guilty that I returned everything 19 times well three magazines to the stores-well sort of guilty-heck I'll take some of the blame-no I won't, I didn't change the darn format, they did!
:woot: ... well never mind it kept you bizzy
I think you made the up the BIG "oops", by stating you made the mistake ..
that takes "balls" to do
Chris
Chris
Btw, I believe there might also be a download available at the DAZ registration link listed in the magazine DVD insert. He might still have a shot at it. I dunno if that's getting mean. :huh:
Quote - :woot: ... well never mind it kept you bizzy
that takes "balls" to doChris
OMG ... now i re read my repley .. i see that my good intensions can be read the wrong way.
IM not DISSING YOU !! i meant you made up as in "made good" not that you lie about it.
I translated my dutch into english the wrong way..
What i "tryed" to say was .. YOU made good on the OOPS by saying you made such mistake.
Because telling honestly you are so mistaken you must have big balls !!
Please understand my writing was with good intentions !!
Chris
Chris
Hi gang, well 3DWorld Magazine Issue 100 finally arrived in my portion of the US.
However, for the first time, my three copies and I repeat three copies of the issue's CD is blank (no autorun, CD title missing (default title CD-RW present), Window's explorer indicates empty disk. In the start/run program list, there are the exe files present along with everything on my other drives, just when clicking on them I get no path found.
Purchased two magazines from Barnes and Noble, with identical problems and one at Books-a-Million--ditto.
Of course the stores were kind enough to refund my money.
Yep, that is the first thing I check, did my CD-RW drive go belly up? The answer is no, my Issue 99 disk works just fine.
Since it happened with three different magazines, two different stores, I'm guessing that there was a reproduction (burning) problem for that batch at 3DWorld Magazine or they changed over to a format that my computer doesn't recognize.
Anyone else in the States having the same problem? Plutom
