Mon, Dec 2, 7:44 PM CST
Subject: V4.2 Arrives! Problems and issues shared here.
Madbat ( ) posted Fri, 15 February 2008 at 1:06 AM
You need to go to the !Daz folder in your runtime/libraries directory, find and run the V4-V3 batch installer for V4-V3 to work properly...I think it's called DzCreateExPFiles-V4V3.bat
dogor ( ) posted Fri, 15 February 2008 at 1:35 AM
That fixed it. Thanks!
Madbat ( ) posted Fri, 15 February 2008 at 1:37 AM
Excellent! :D
FarawayPictures ( ) posted Fri, 15 February 2008 at 2:02 AM
Installed it last night. It would only install to the main poser folder, but when that was done I just moved it to a seperate runtime. Works fine, and I have 4 and 4.2 working seperatley.
Also, just for note, I saw Daz have some 4.2 stuff 50% off. I bought the catsuit and expansion set for £12.
PORTAL
Madbat ( ) posted Fri, 15 February 2008 at 2:20 AM
I used my coupons and snagged the bodysuit expansion!.
I don't think there was an issue with 4.1 and 4.0, just 4.1 and 4.2. Some people are having a heck of a time, and some aren't.
TrekkieGrrrl ( ) posted Fri, 15 February 2008 at 5:19 AM
Hm I just installed V4.2 into my V4 PBooost bank. Everything works.. EXCEPT the male morphs. Also all the morphs were already injected so I suppose there's something leftover from a previous version (I have V4.0 in the same folder. Can't remember where I put V4.1)
So in short it seems like what I have is a hybrid now. The male FACES works, but not the body sigh And those were my only reason to update...
Madbat ( ) posted Fri, 15 February 2008 at 10:18 AM
Trekkiegirl, I had the same problem. I have V4.1 in 2 different runtimes, and got the same hybrid you did when I installed V 4.2 (Into DazStudioContent) I was able to solve the problem by cutting the connection between runtimes, restarting and reinstalling the V 4.2 Those two gals really don't seem to mix well
tuxedomask ( ) posted Wed, 05 March 2008 at 7:10 PM
Is there anyone who can help me there With V4.2/A4 .I have been struggling for the last 2 weeks to fix the problem of no body morphs for either of them.I installed everything as I was told to and althought both models will pose to a particular body pose (sitting , lying etc) they do not respond to facial morphs or any of the 4 standard body morphs for  A4.DAZ has been less than helpful.All they keep saying is to follow the thread on how to install V4.2.Which I have done  and still V4.2 does not work properly.I must admit that I am not that clever when it comes to the computer and do have a basic knowldge of things .i am using poser6 i have installed the V4.2 and the V4.2 morph+++.I Have run the !DAZ files and the updater  and also injected the morphs but still V4.2 does not work .
Can anyone help me to get V4.2 working ?Or tell me where the files should be  to get her to work .I am totally relying on the installers .And they maybe installing into a wrong folder.I'd appreciate the help .that is if anyone can .
Madbat ( ) posted Thu, 06 March 2008 at 3:05 AM
Do you have a V4.1 still installed in a separate runtime? If so this can cause conflicts with V4.2.
tuxedomask ( ) posted Thu, 06 March 2008 at 6:32 AM
No i don't have  any of the Victorias  except for V4.2 she is the only one I have .
Madbat ( ) posted Thu, 06 March 2008 at 4:59 PM
Odd?! Are you installing to Daz or Poser?
Did you try a reinstall of the morphs and running the updater? I wonder where RHasseltine is when you need him...this sounds like something up his alley.
tuxedomask ( ) posted Thu, 06 March 2008 at 5:53 PM
I am installing to Poser6 and yes i have tried a reinstall of the morphs and running the updater.But this did not work also .i have even uninstalled Poser6  and all its contents and started with a fresh install of Poser6  and installing V4.2 , Morphs+++  and Aiko4  with nothing else in Poser.This did not work either ,i have also run the !DAz bat files .Which did not help either.i wonder if its in the right directory ?How can i check if All files are in thier right directories?
Madbat ( ) posted Fri, 07 March 2008 at 12:27 AM
It sounds like everything is going into the right directories. If you've installed all the morphs then they should be injectable...All I can recommend is to have another go at the Daz forums, and give as detailed a description of your problem and what you've tried as you can.
tuxedomask ( ) posted Fri, 07 March 2008 at 6:36 AM
ok thanks for your help .But honestly do you think anyone can really help me find out thats going wrong  with V4.2 /A4  and why the morph dials are not appearing.Do you think I'm not injecting the morphs properly ?Thanks once agaiin .
nickedshield ( ) posted Fri, 07 March 2008 at 9:01 AM
Question: Did you run the new initilization bat file?
tuxedomask ( ) posted Fri, 07 March 2008 at 6:46 PM
I run all the files it asked me to and have installed all the files that where supplied.And have initialised all files i was asked to .I'm not sure what you mean by the "new initialisation bat file" ? CAn you be a bit more specific.
Thanks
Madbat ( ) posted Fri, 07 March 2008 at 7:01 PM
The install asks you to update V4.2 after install, and after installing the morphs. It also puts an 'Update V4.2base' icon on your desktop, I take it you ran that?
nickedshield ( ) posted Fri, 07 March 2008 at 9:33 PM
Yes, that is what I was referring to.
tuxedomask ( ) posted Sat, 08 March 2008 at 7:10 AM
Good news !! I have managed to solve part of the problem. I now have the morph dials for V4.2 and A4 .But A4 still wont morph to her petite morph when I click the icon for the petite body morph, and she wont morph to some of her facial morphs .V4.2 is the same wont morph to any of her icon in the drop down menu.How did I fix it  partially ? I was not clicking on the actual character listing when it came to the morph injections,If you know what I mean .In the character listing there is a White + symbol on the character Icon and up until today  i was not aware of this and did not know that I had to find that and click on that to inject the morphs.
So thank you to all the people who have tried to help me resolve this .It was your encouragement and perserverance that helped me  to find a solution.
Madbat ( ) posted Sat, 08 March 2008 at 8:22 PM
Well, at least you have part of the problem solved.
tuxedomask ( ) posted Sun, 09 March 2008 at 6:20 AM
Yes and thank you for your help with this problem.
