Tue, Nov 19, 5:35 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: you can tell i'm a newbee by the question I ask
RedPhantom ( ) posted Fri, 15 February 2008 at 12:20 PM · edited Tue, 19 November 2024 at 5:18 AM
Site Admin
How do you lower the horizon? I'm wanting an image with about 3/4 of it sky and the rest ground.  The problem is when I lower the terrain, it looks like it is surrounded by water. Changing the camera angle isn't helping. is there another way?
orbital ( ) posted Fri, 15 February 2008 at 1:19 PM · edited Fri, 15 February 2008 at 1:20 PM
No you can't physically move the horizon position in Bryce. The only thing you will have to do is raise the camera to a higher position and tilt the camera to the desired angle.
Welcome by the way!
http://joevinton.blogspot.com/
TheBryster ( ) posted Fri, 15 February 2008 at 3:08 PM
Forum Moderator
I think you might be lowering the terrain below the infinite ground plane.
Check the position of the terrain by using one of the horizontal views. You probably want to raise your terrain so that most of it is just above the plane.
After adjusting, reset your camera view.
Welcome to the Asylum!
FranOnTheEdge ( ) posted Fri, 15 February 2008 at 6:50 PM · edited Fri, 15 February 2008 at 6:52 PM
Use the biggest button, and drag up or down to adjust the 'appearance' of the horizon level.
You can then further adjust by dragging the Y axis.
P.S. there are no daft questions - not anymore anyway - I asked them all. Lol.
Otherwise the horizon is stubborn.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
pakled ( ) posted Fri, 15 February 2008 at 10:59 PM
we were all once where you are now (heck, I'm probably still there...;) ask away...
dhama ( ) posted Sat, 16 February 2008 at 2:28 AM
@FranOnTheEdge..... Excellent. This is the best way to describe things to newcomers. :thumbupboth:
RodsArt ( ) posted Sat, 16 February 2008 at 2:52 AM
One other shortcut to moving your screen: Using your thumb(hold the space bar on the keyboard which changes your cursor arrow to a hand....now you can manually drag up-down-left-right. (no rotation though).
Here is an outstanding Reference page for starting out....I STILL review it from time to time.
http://stevesartgallery.bryce-alive.net/tutorials/bryce/keyboard/shortcuts.html
Welcome to the Machine!
___
Ockham's razor- It's that simple
