If you think it is a permissions problem use the disk utility app and repair permissions. Have Vue on order so I am not a real user until a few more days. Is there a setting in the prefs that you set as a target to where you save files? User name for old machine to new machine the same? Drive names the same? Those are a few things I would check. Sounds to me like Vue doesn't recognize either its location or you as a user.
Gary
You guys are great! Wabe, as soon as I read your post, I realized that I had had some trouble with transferring my login, so I followed grichter's advice to check it with the utility (I used the installer utility); sure enough, when I reset my admin password, everything started working.
I'm grateful, but a little embarrassed, as I used to provide Mac support in-house at a publisher, and should have been able to figure this out on my own...
Quote - You guys are great! Wabe, as soon as I read your post, I realized that I had had some trouble with transferring my login, so I followed grichter's advice to check it with the utility (I used the installer utility); sure enough, when I reset my admin password, everything started working.
Glad it worked...I am climbing the walls waiting for my copy of Vue to show up. When it does I am sure you can return the favor and answer my question(s). However I am sure I will have more then one :)
Gary
Hi. I just got a 2.8 GHz Intel Core 2 Duo iMac, largely in order to speed up my renders from my previous platform, a G5 iMac. I was running Pro Studio 6.50-04 build 291916 on that setup with good results/ I used Migration Assistant to move my stuff over to the new setup, and it renders like a dream. Unfortunately, it won't save .vue files (I get a dialog stating that it's impossible to create the file), it won't save animations (a dialog reads that a Quicktime file could not be created), and it won't save stills (crashes every time!). So that render speed is kind of useless right now...
I've completely deleted all Vue 6 files from the Intel iMac and manually copied the installation files from the G5, but after re-installing there's no change.
Any thoughts on where to go next? Thanks.
