Mon, Jan 20, 12:08 PM CST
Subject: Need help with BAD Media.
Thanatos ( ) posted Mon, 11 June 2001 at 10:52 PM ยท edited Tue, 07 January 2025 at 12:34 AM
In some instances and I don't know what is causing them, when I export an obj figure from poserpro to bryce I get a dialog box that says. A file error has occured i/o Bad Media. This prevents loading of the model and some fantastic figures are going to waste as a result. What can i do other than load the figure as a crummy 3ds or dxf.
Amixiam ( ) posted Tue, 12 June 2001 at 1:05 AM
I had this problem as well...there must be a prop that is attached to the character that bryce cannot load properly. In my instance I had a p4 character, armor, a shield, and a sword. The shield was the only thing causing the error message...however, when I imported the shield in its normal 3ds format, everything was fine. I highly doubt that any props in poser format or textures etc are causing the problem. check to see what all formats make up the sum of your posed figure in poser and start deleting unnecessary props that you can always add after the main figure is imported. You might also check to see if you are using Grouper 1.1. Very rarely does it create a corrupt obj file, but it can happen. Hope this helps. Bryan
offrench ( ) posted Tue, 12 June 2001 at 2:26 AM
Attached Link: http://home.pb.net/~stevecox/uvmapper.htm
Hi, I have had this problem since I installed Poser Pro Pack. There are apparently errors in the .obj files it exports. If I remember well (not 100% sure and I can't check from work :-)) I solved the problem by loading the file in UVMapper and simply saving it once. I was then able to import it into Bryce with its characteristics unchanged. Hope it'll work for you.
Fantasy pictures, free 3d models, 3d tutorials and seamless textures on Virtual Lands.
KenS ( ) posted Tue, 12 June 2001 at 2:39 AM
that sounds like a great idea, when running the obj through uvmapper, it doesnt affect the poser textures in anyway does it? and you just resave the .obj and thats it? Ken
offrench ( ) posted Tue, 12 June 2001 at 6:53 AM
I'd have to retest it in order to be sure but it should work. I have been using UVMapper for Poser obj file correction since Poser 3. There might be another solution though. I have just downloaded service release 1 for Poser Pro Pack from CuriousLabs and maybe it addresses this problem. You should try this first.
Amixiam ( ) posted Tue, 12 June 2001 at 10:02 AM
The SR1 for PPP doesn't address this problem...though I tested uvmapper with the original file that I was having problems with and it seemed to work. The obj loaded into bryce without error and the textures were unaffected, though I didn't scrutinize once I it loaded into bryce. Bryan
KenS ( ) posted Tue, 12 June 2001 at 1:00 PM
thanks mfor the info, Ill have to test it with some of my known promlem figures. Ken
