Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
No way to do that... just remember to clear all unused shaders and objects before save.
Follow me at euQfiz Digital
Quote - No way to do that... just remember to clear all unused shaders and objects before save.
Not quite correct.
If you save your poser objects to a poser scene file and then use transposer to import them (vs dragging them from the browser) C6 will not save the poser geometry and just point to the poser scenes.
Now if Poser saves a copy of each object in it's scene file then you would not be saving any space from duplicates.
I am not sure how poser saves its stuff.
wayne k
guam usa
Hi, all --
I'm creating a five minute movie with about 110 shots in it. Each shot has a model or two from the Poser Runtime folder. When I bring those models into the Carrara scene, Carrara then saves the geometry in the .car file, effectively doubling the number of times the geometry resides on my hard drive. Some of these files are getting huge.
So, is there a way to have Carrara just point to the geometry in the Runtime folder, thereby significantly reducing the size of the .car file?
Thanks for any info,
Dex
