Wed, Sep 18, 5:16 PM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Bug: Setting Texture Map String for Image Node
dburdick ( ) posted Wed, 27 February 2008 at 1:23 AM · edited Sun, 15 September 2024 at 11:46 PM
I ran across this annoying bug when setting a texture map string in an ImageMap node.  Here's what I'm doing in Python:
  1. Get the texture pathname for a material (e.g. SkinTorso)
  2. Load in a mat pose file for that material (e.g. load mat.pz2)
  3. Find the image map node for the newly loaded material and change the image texture back to the original pathname captured in step 1
Everything get sets just fine, but when I go into the material room or render, it says it can't find the .jpg file even though it's listed correctly in the node.  This only happens when I try to set an image file that has previously been loaded into the Poser scene.  If I assign a completely new image file to the Image node via Python, no problem.
I suspect this relates to bugs with how poser is cacheing files and it's getting confused when you set an image via Python that is already in the cache.
Thoughts?
markschum ( ) posted Wed, 27 February 2008 at 1:43 AM
did you do the refresh tree thing ?
dburdick ( ) posted Wed, 27 February 2008 at 3:27 AM
Quote - did you do the refresh tree thing ?
Yes I did.  Didn't make any difference.  Anyway, I built a workaround by programmatically stuffing the original texture map pathname into the pose file and injecting the whole thing.
