Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 08 5:10 pm)
I ran across this annoying bug when setting a texture map string in an ImageMap node. Here's what I'm doing in Python:
Everything get sets just fine, but when I go into the material room or render, it says it can't find the .jpg file even though it's listed correctly in the node. This only happens when I try to set an image file that has previously been loaded into the Poser scene. If I assign a completely new image file to the Image node via Python, no problem.
I suspect this relates to bugs with how poser is cacheing files and it's getting confused when you set an image via Python that is already in the cache.
Thoughts?
