Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 03 9:02 pm)
Attached Link: Why it takes loads of time to open file with 3 DAZ V3/M3 textured characters?
Deleting Morph Parameter Dials, is a great way to save space in your scene; especially when they are just set to 0(useless.) And consolidating the ones with values is another way to save space.A dial is just the visible manifestation of a channel. So the first question is do you want to get rid of the dial or the channel as well? In a Poser library file, each channel has a parameter named 'hidden' which has a value of "1" = hidden, or "0" = displayed. To hide the dial you can change this value either by editing the file in a text editor, or by applying a pose in Poser.
To delete the whole channel, if the file is stored in an uncompressed format you can delete the channels in a text editor, or a cr2 editor such as CR2Builder, or Cr2Editor. If the file is in a compressed format you will have to decompress it first.
To give any more advice I would need to have a better idea of exactly what you are trying to achieve.
Is there a way to delete some of the Parameter Dials of a figure?
Thank you
