Check to see that you have the correct version (ie V4 for V4)...then, look to see you do not have an upgrade (this happened to me) for Aiko x.xx & Stephanie Petite x.xx. It won't even work for them unless you have the original for V3 or V4 installed first.
Hope that helps.
Yank My Doodle, It's a
Dandy!
Contact the vendor. From my experience, he's a very helpful guy.
One common cause of Body dials not having the expected affect on PBMs in body parts, is that the figure you've INJected them into isn't the first one to be loaded in to the scene.
The simplest solution is to have a blank scene as the default.
If other INJected morphs are working, you'll need to go into more detail about what you're doing before you INJect the NGM.
After injecting the NGM morph, scroll down and double click the size you want... there's presets for differing size breasticles in the NGM (V3) folder!
Hope you get 'em working as they work great!!
Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
Nruddock, tried applying the morphs on a model that was the first model in a new scene. Still no luck. Grrrr.
Jan, the head and morph packs for V3?
Gerard, yeah thats what I've been doing. Dosen't change the model at all or add any sliders or do...anything really.
Still trying. I'm fairly computer literate as well. Seems like it should be easier than this.
That's weird!!! Too bad too as they really do work great!! If I didn't purge my gallery you'd see some really great examples of how great they work!! Rats!
So, V3 WITH head (not really needed for NGM) and body morphs from DAZ, NGM morphs injected and nothing???
Really weird!! What version of V3 are you using??? That may play into things!
Gerard
The GR00VY GH0ULIE!
Do you have the latest update of NGM or an old version? The old version needed a special V3-cr2 file to work, cause in didn't had the right channels to let it work with the original V3-cr2. The latest update has a special python script and works with the original V3-figure.
Bopper.
Hi, there are two possible problems here: one is that the inj files are not in the right place and the other is that you don't have the right version of V3.
Since you can see a PBM dial in the body part then the files are at the right location so we don't have to worry about this :)
This lead me to think that the version of your V3 is an old one so please go to the DAZ store and redownload a fresh V3 which should be the SAE edition or the SR2.
This versions had more empty morph channels in the CC (community channels) area than the old ones and NGM products use more or less the last 10 channels to avoid conflicts with other injectable characters or morphs.
The head and body packs use another set of empty channels, they use their own set named DC (Daz channels) so you can feel confident working with those and with the NGM ones.
Thanks for all for the support here, glad that you all enjoy working with NGM!
Gerard
The GR00VY GH0ULIE!
I can't get any of the NGMs to work. Not for V3, not for GND. Nothing.
I apply the INJ but nothing happens. Well, I guess something sort of happens. A dial appears in the "Body" tab called "PBM-NGM-E" but when I spin that dial...nothing happens. Nothing happens when I apply any of the specific morph poses either. For instance if I apply the NGM-B pose...nothing happens at all. No dials appear, nothing changes. Any suggestions?
