Beautiful but maybe you ought to just tone down those blues? Give it a lighter or darker shade of blues and greens, perhaps? Otherwise it is very bluuuutiful!
TS
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Might work with just a few of those sparkles on just the dragonfly... Otherwise I agree with Wildman2, a bit busy.
low light.... box.... hmmm.
I've got a lightbox. No means of printing it onto clear plastic though.
Thunderstone, I don't think it's possible to get the blue mats any darker in Bryce, there might be by doing it your way though, through photoshop, not really sure I'd want to, as I took a long time adjusting the camera angle to get the tone of blue I wanted...
The greens you can get a little darker, but not much, a more olive green shows up darker though, but I don't like that hue so much.
I did wonder about water, not sure it'll show up in this dark scene, worth a try though... I'll see what happens.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Analog-X,
I'm afraid I still don't like that much. I feel that the lack of most of the black background has taken away a lot of the initial impact that I liked, the contrast between the glowing blue and the simplicity of the black.
I have tried a render with a river terrain, but I kept the terrain dead black and just added caribbean to the water, it gave me some nice subdued reflections.
Let's see if it's small enough for the forum...
Measure
your mind's height
Analog-X,
Measure
your mind's height
There we go.
I suppose I could try adding some tiny fireflies in the black space above the flowers... but not too many.
Um, now where would I find a firefly model?
Measure
your mind's height
Tried reducing the dragonfly as a stand in for a firefly, which worked okay, but I'm having problems getting the glow to look right... any ideas?
rendering now...
Measure
your mind's height
Can you do a quick modeling of a firefly using 2 spheres and some lattices as legs and antennas and something else for wings????
Well I've been using the dragonfly but actually I'm not sure a model is necessary, wouldn't you just see the glow?
Which is why the glow is so important, and probably why I'm having trouble with it...
Does anyone have or know where to find or how to make a 'glow' material.
The x-ray mats are too.... solid for this.
Measure
your mind's height
Yeah... use any color or object and pump up the ambiance ???
Measure
your mind's height
Any ideas?
(Oh, and the ambience is already at 100%)
Measure
your mind's height
Make it smaller? Is that a sphere?
Which is an adjustment of an adjustment of Clay's volumetric fire.
I've pumped the radial light up to 999 radiance, trying to get it brighter, with the falloff on 'ranged' and set to 40.
Upping the range to 90 makes no difference whatsoever.
Maybe if I try using a group of spheres...?
But I think I need a different mat for this to start with.
Analog-X, which bit? The water or the firefly?
Measure
your mind's height
How about turning off the fall off and playing around with the intensity and the color ? using gradients? and or gel?
Thunderstone, tried that - makes not difference whatever.
By the way I'm not rendering the entire image, since I don't want to bleach out the flowers etc - which these settings do, or would if I rendered everything, so I'm just rendering the firefly and the glow...
Measure
your mind's height
Well I didn't have one but I'm making one from the original texture.
Measure
your mind's height
hi fran,
sorry..late reply... i hate packing.
ok..don't like the dragon fly because the finer bits on the wings don't show up. it out to be more see thru.. more xrayish..like xrayclark says.
i love what you did with the garden though..brilliant work! keept he pure black background..it is what maks the pix stand out.
cheers...
btw..will work on it once i start brycng after my travels!
How's this looking? it's just the dragonfly and one flower - takes too long to render the whole thing.
Measure
your mind's height
Attached Link: The Night Garden
I've put a new image in my gallery, and wondered what you lot think of it, I'm particularly interested in the dragonfly as I tried out a trick with the wings and I'm not sure if it works in this scene or if I could improve it.You see I'm using erosiaart's laser flowers idea with the Adamite xray mats. Well... I started with those mats and then adjusted them somewhat to produce a greater range of colours.
The dragonfly is a freebie from boroda (in Rendo's freestuff) and comes UV Mapped - I took it into wings, tidied the model up a bit, and then separated some areas from the UV Maps so I could try out this trick...
the one I'm not sure of...
I left the uv map on the underside of the wings and put an x-ray mat on the top surface, in this way I hoped to keep some of the wing tracery from the uv's and yet still get the glowingness of the x-ray mats.
It's sort of worked, I can still see the wing tracery and I have got a different colour to the wings, but the 'glowingness' is not really there.
I felt it still suited the ambience (feel) of the scene but just wondered if there might be a way to get more glow... what do you think?
(Oh, I also put x-ray mats on most of the rest of the dragonfly - all I left are the underside of the wings and the legs)
Measure your mind's height
Fran's Freestuff
http://www.FranOnTheEdge.com
