I got this myself, and the way I fixed it was to forcibly remove all previous files related to V4 in the !DAZ directory (be very careful doing this if you choose to) and re-install. Apparently the DAZ installer is sloppy and fails to keep the new 4.2 files properly separated from previous versions.
Sigh.
Known Problem
You didn't uninstall V4.1 before installing 4.2.
You will need to uninstall all V4 and morph++ files from your runtime, reinstall V4.2 and the V4.2 versions of the morph++ files. If you have the creature creator or Muscle morphs, they too will need to be deleted and replaced with 4.2 versions
I've been using V4.2 and noticed that the EyesOpen-Close, EyeOpen-CloseR and EyeOpen-CloseL morphs don't appear to work on the figure. When I spin the dials in either direction to their min/maxes (.5 to -1) I can see the eyelids move only a bit, its so slight that I wouldn't notice unless I was watching the screen. I randomly checked a number of other morphs and they seem to work fine (I don't have time to check every single one, obviously). Is this a problem for anyone else? I'm using P7, latest service release.
Thanks for any info.
