Sat, Jan 25, 4:07 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Texturing Help
Thelby ( ) posted Mon, 10 March 2008 at 4:56 PM · edited Tue, 14 January 2025 at 9:39 PM
OK, Now that I have a cute little Bank Building that I pushed and Pulled into place, How Do i Texture it so it looks like a building or am I going at it all wrong???
I would rather be Politically Incorrect,
Then have Politically Correct-Incorrectness!!!
bwtr ( ) posted Mon, 10 March 2008 at 8:28 PM
Perhaps the very next, first step, (In the Vertex Room) is to create the "Shading Domains" to which you want different textures allocated.
bwtr
Thelby ( ) posted Mon, 10 March 2008 at 10:35 PM
Thank You, I'll try to get back in there and find it. Much Appreciated!!!
Thelby ( ) posted Mon, 10 March 2008 at 10:53 PM
OK, SO how do I create more than 1 Domain for a single object, because that is what my Bank is, 1 cube.
Angelouscuitry ( ) posted Tue, 11 March 2008 at 12:03 AM
I figured the first step would be to create Carrara's version of a Poser Material Zone; so I'm lurking just to hear more.
But have you considered exporting an .OBJ of the model; importing into the free UV Mapper application, and exporting a UV Map?  You could bring the UV into Photoshop an paint on whatever you want.
JohnMalv ( ) posted Tue, 11 March 2008 at 1:13 AM
Try this:
  1. Highlight the faces you want to include in the domain.
  2. Under the Model tab you'll see the heading Shading Domain with a blue drop-down menu. (you will only see this option if you have one or more faces selected)
  3. Click the menu and select "New Shading Domain"
  4. A box will pop up where you can name the new domain.
  5. Repeat this for every domain you want to create.
Thelby ( ) posted Tue, 11 March 2008 at 4:12 AM
Thanks John, I will give it go now!!
Much Appreciated,
Thelby
bwtr ( ) posted Tue, 11 March 2008 at 4:33 AM
Using the Help can be a big help!
bwtr
boeing ( ) posted Wed, 12 March 2008 at 10:15 PM
I knew that was coming :)
