Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 2:02 am)
As long as all the texture references in the PP2 are in relative form, that
should be all you need. The original folders won't matter unless the
PP2 names them specifically.
For instance, here's a material paragraph from the item I was just working on:
material plate
KdColor 0.87451 0.996078 0.980392 1
KaColor 0.376471 0.249412 0.161569 0
KsColor 0.870588 0.870588 0.870588 1
TextureColor 1 1 1 1
NsExponent 30
tMin 0
tMax 0
tExpo 0.6
bumpStrength 1
ksIgnoreTexture 0
reflectThruLights 1
reflectThruKd 0
textureMap ":runtime:textures:DreamVillage:1950Kitchen:plate-1950.jpg"
0 0
bumpMap NO_MAP
reflectionMap NO_MAP
transparencyMap NO_MAP
ReflectionColor 1 1 1 1
reflectionStrength 1
If you left the prop in 'embedded geometry' form, which is how Poser creates it...
then you really don't need to include the OBJ and MTL file unless you want
to make the OBJ available to users of other 3d programs. Poser doesn't need
them when the PP2 contains the information from the OBJ.
My python page
My ShareCG freebies
I usually open up the PP2 files in a text editor and look through the file paths just to be sure they are relative ones, not absolute.
If I get lazy, I just zip from the prop folder level down. Which isn't very helpful for Poser newbies re, the runtime hierarchy etc. Otherwise, yes, I get a separate runtime done up the way you have, Pakled.
Eternal Hobbyist
so far, so good. I'll have to fire up a text editor and see what I have...thanks to all so far. Don't stop with helpful suggestions on my account. If I ever master UVMapping, I'll be flooding the freebies section...;)
Instead of a texteditor for editing pp2-files, you can also use CR2-editor, which is free and can not only edit cr2-files but also all other poser -files. it has as easy find and replace to change all the references of object and textures files to the right location.
You can find it on english Bob site in utility-section:
Bopper.
Great prop, BTW!
Attached Link: http://forum.daz3d.com/viewtopic.php?t=79526&highlight=freebie+providers
**Pakled,This might also help with creating the folders. A bit more detail on the filepaths and what not.**
Pakled, that's looking very nice, good job!!!!!
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Morn'ng Pakled, I just downloaded your Raygun. You did an excellent job with your model.
I downloaded it to my Poser 5 root directory and everything got to the right places even the textures (sometimes I have to search for textures on some downloads-yours came up just fine). I simply click on your image in the props section.
Another thing I like is the size of the .zip. Even with a 56KModem it download quickly.
I believe, if you follow your same format, you can add to your installation instructions-download to Poser 5, 6, 7 root directory. Again great job. -- Jan
Ok, here's what's been done so far.
Created a model in Wings 3d. UVMapped, applied texture, 'poserized' it (slight bevel to sharp edges to keep them in Poser).
Imported it into Poser. Scaled it for Don (he was just sitting there...;), and actually parented (my first...;) it to the left hand (nobody's perfect, I'm a lefty). Saved it as a prop.
So I have a Prop, parented, saved to one directory, and textures for another. It looks...uh...well, it's a first effort..;)
Now, having done that;
I created a 'runtime' directory on C:, and Geometries, Textures, and Libraries/Props folders, each with a 'Pakled!!' folder (my joke about all those !!!Whatever directories...;)
The pp2 and png are in props, obj and mtl in Geometries, and textures in textures. A readme
is in the Runtime Directory itself. Has my handle, where I hang out, and what (pretty much no) rules to follow.
Zipped the 'Runtime' Directory into one file. Created a ShareCG account (boy is that sobering...you'll never get rich that way...;) and am ready to upload.
Now all the files are where they 'should' be, but since the prop was created in other directories, will the thing work? How do you have the prop point to the 'correct' folders? Do I need to hack and create a cr2 file? or is this something I can correct inside Poser?
BTW...I looked in the Freebies forum a bit, but didn't see a sticky on how to make actual freebies...mebbe they should have one...;) And if anyone wants it, I'll post it as soon as I have the answer...;)
just stuck it up in the gallery, if ya wanna look. Scathing criticisms and helfpul advice appreciated...;)
