Forum Moderators: Lobo3433 Forum Coordinators: bwsupport
Blender F.A.Q (Last Updated: 2025 Feb 17 11:37 pm)
Quote - i have been useing blender now for about six months and just started doing animation.and i got a couple of questions the frist is how do you save a animation and the2nd is is what format do you use ie:codec. any help wil be most welcome .thanks
tom
If I remember correctly, the saved animations will go in the fold set as your 'temp' folder. Drag the edge of the menu bar down to see these options and go to file paths.
First set your frame options here under the 'Scene(F10) menu. Format Tab. Frame size, frames / sec, output format - AVI, or multiple images, etc.
The drop down button allows you to select the output format: I usualy use 'AVI Raw' which seems pretty universal.
Under the 'Scene (F10)' buttons, instead of clicking Render, you'll want to click 'Anim' under the 'Anim' tab. First set your start and end frames here under the Anim tab too.
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
Quote - thanks reddog all the tuts i looked at were not that clear on how to save your life saver.
tom
You're welcome. Stick with it. It's a terrific program.
Reddog9
Wellcome, tom
I'm going to give an advise about saving animations.
If you are rendering an .avi and then electric supply is down, computer crashes... you will lose all render.
So, for high render times, rendering in an image sequence is a better solution.
An option is saving as Targa, then composite in Sequencer, rendering the composition clicking in "Do sequence" before clicking in "Anim".
tom
