Thu, Nov 28, 10:36 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: new to blender
tom72255 ( ) posted Tue, 18 March 2008 at 7:05 PM · edited Wed, 06 November 2024 at 2:08 AM
i have been useing blender now for about six months and just started doing animation.and i got a couple of questions  the frist is how do you save a animation and the2nd is is what format  do you use ie:codec. any help wil be most welcome .thanks
        tom
Reddog9 ( ) posted Tue, 18 March 2008 at 8:32 PM · edited Tue, 18 March 2008 at 8:33 PM
Quote - i have been useing blender now for about six months and just started doing animation.and i got a couple of questions  the frist is how do you save a animation and the2nd is is what format  do you use ie:codec. any help wil be most welcome .thanks
        tom
If I remember correctly, the saved animations will go in the fold set as your 'temp' folder.   Drag the edge of the menu bar down to see these options and go to file paths.
files
First set your frame options here under the 'Scene(F10) menu.   Format Tab.   Frame size, frames / sec, output format  -  AVI, or multiple images, etc.
format
The drop down button allows you to select the output format:  I usualy use 'AVI Raw' which seems pretty universal.
format2
Under the 'Scene (F10)' buttons, instead of clicking Render, you'll want to click 'Anim' under the 'Anim' tab.  First set your start and end frames here under the Anim tab too.
anim
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
tom72255 ( ) posted Tue, 18 March 2008 at 8:43 PM
thanks reddog  all the tuts i looked at were not that clear on how to save your  life saver.
        tom
Reddog9 ( ) posted Tue, 18 March 2008 at 10:15 PM
Quote - thanks reddog  all the tuts i looked at were not that clear on how to save your  life saver.
        tom
You're welcome.  Stick with it.  It's a terrific program.
Reddog9
tom72255 ( ) posted Tue, 18 March 2008 at 10:29 PM
i know it is.im new to 3d world and went cheap.and i have learned alot in six months. was working on a cuckoo clock modle and thought it would look better animated. after i get it saved i will post it .
 tom
vespertilum ( ) posted Sat, 22 March 2008 at 5:55 PM
Wellcome, tom
I'm going to give an advise about saving animations.
If you are rendering an .avi and then electric supply is down, computer crashes... you will lose all render.
So, for high render times, rendering in an image sequence is a better solution.
An option is saving as Targa, then composite in Sequencer, rendering the composition clicking in "Do sequence" before clicking in "Anim".
tom72255 ( ) posted Sat, 22 March 2008 at 6:10 PM
thanks for the advice vespertilum will try that.
                                                 tom
