Wed, Jan 8, 10:22 PM CST
Subject: Light Question
Anniebel ( ) posted Fri, 28 March 2008 at 1:36 AM · edited Wed, 08 January 2025 at 3:22 AM
How do you make shadows darker & crisper without making the figure too bright?
I am trying to match the dark crisp shadows from the figure in the original picture in my poser scene. The original figure for example is in the bottom left.
I have 2 lights so far, an IBL probe to light the scene with a poser 7 probe attached, shadows off & an infinite light for the shadows.
If I turn up the light colour / intensity to get darker shadows, the figure is too bright.
Click on the picture to see it clearer, the forum will resize it.
Suggestions would be appreciated, thanks.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
markschum ( ) posted Fri, 28 March 2008 at 2:25 AM
at the bottom of the preview window there should be 4 circles. If you place the mouse over the second from the right you should see shadow color at the top of the preview window .
That lets you set the shadow color for the scene. If you set it to BLACK you can adjust shadow intensity in the light parameters .
Anniebel ( ) posted Fri, 28 March 2008 at 2:32 AM
In that render the shadow colour is black.
Helen Keller
Anniebel ( ) posted Fri, 28 March 2008 at 2:57 AM
:blushing: ok duh I just realised I can make the intensity more than one, I thought one was the max
Helen Keller
Acadia ( ) posted Fri, 28 March 2008 at 3:06 AM
I wanted less dark shadows and when I asked about it, I was told to go into the parameter dials for each light and lower the shadow intensity.  It works really well.  I usually change it to  between 60 and 80.  If you want darker ones, try increasing the value.
You can also go into the properties area of the parameter dials and turn off shadows for certain items/parts.  I always turn off cast shadows for hair that is neck length or longer as I don't like the black voids at the neck that long hair tends to have with shadows turned on.
Anniebel ( ) posted Fri, 28 March 2008 at 3:25 AM
I had the intensity down to 80%, because over that the scene was too bright. Increasing the shadow from 1 to 1.6, seems to give the effect I want.
Helen Keller
