Mon, Nov 25, 7:28 PM CST
Subject: How do I export as .3DS?
dhama ( ) posted Fri, 28 March 2008 at 4:15 AM · edited Mon, 25 November 2024 at 5:04 PM
All parts were sperate except for Pos/Neg groups. I selected all and grouped everything together and selected the 'C' convert button. Then I exported. All I got was a small part of the complete object as .3DS.........
What have I forgotten?
AlfRaMusic ( ) posted Fri, 28 March 2008 at 6:46 AM · edited Fri, 28 March 2008 at 6:49 AM
Every single object and also every single group must be positive or negative, for the export.
Example:
cube one positive----cube two negative----grouped the new object is neutral---set it to pos. or neg. then it should work.
If you forgot to set one or some groups...objects to pos. or neg. it will not be exported just the others.
Only 3D and Bryce, comes at my pictures!!!
dhama ( ) posted Fri, 28 March 2008 at 8:46 AM
So all cubes could be positive then......?
Thanks. :-)
AlfRaMusic ( ) posted Fri, 28 March 2008 at 9:10 AM
Yes they all could be positive, just not neutral.:-)
Allibaba
dhama ( ) posted Fri, 28 March 2008 at 11:00 AM
👍 Thanks.
dhama ( ) posted Fri, 28 March 2008 at 2:02 PM
Ok, heres what i'm getting. There are 6 (pos/neg) boolean groups. I convert all seperatly.
I then select all the other single elements, make them positive and group them. The I convert that group.
After I have export and check the model, it only contains the 6 (pos/neg) boolean groups and a small section of the other elements.
Tried this with .3DS and .OBJ, same thing happens.
Any ideas?
AlfRaMusic ( ) posted Fri, 28 March 2008 at 2:38 PM
Strangely??? I have, tries out in order to test, what I, explained maybe incorrectly, but everything worked out with me. The objects are complete, after the import. It seems, some parts of your objects are not converted????? There, I now am helpless.
What I also realized is, the objects should not be scaled to zero on one of the sides, that eliminats them.....
dhama ( ) posted Fri, 28 March 2008 at 2:57 PM
Maybe I should group in sections and convert rather than leaving most of the parts as single entities.
AlfRaMusic ( ) posted Fri, 28 March 2008 at 3:16 PM
I just had wanted to propose this. ...because I cannot recognize where the difference is, if?, between our procedures? Sorry!!!!
dhama ( ) posted Fri, 28 March 2008 at 4:11 PM
No need to apologise, thanks for your help. 😄
FranOnTheEdge ( ) posted Sat, 29 March 2008 at 7:59 PM · edited Sat, 29 March 2008 at 8:01 PM
Everytime you group, that group must also be not neutral.  If there is just one thing in the model that was not changed from neutral, either a group or a mesh in a group, then it won't work properly.
I have had this happen to me and I just had to go back and ungroup and check every little thing - there always turned out to be one (or sometimes more than one) thing that was still neutral.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
electroglyph ( ) posted Sun, 30 March 2008 at 6:04 AM
Just remember that the pieces are still pieces. Here are 5 bryce cubes. The top is negative and the others are positive. The last two blue ones are identical in materials.
electroglyph ( ) posted Sun, 30 March 2008 at 6:06 AM
Group, collapse and export so far so good.
electroglyph ( ) posted Sun, 30 March 2008 at 6:15 AM
Import the 3ds object back and you find that every block has become a seperate open surface even the blue ones that had the same material settings. They can be moved around because the vertexes were not welded. Thet are also not closed objects. That's also why you can't boolean twice in Bryce. To weld the pieces together you have to use weld in wings or join in rhino or some other program.
dhama ( ) posted Sun, 30 March 2008 at 10:37 AM
Thanks electroglyph, and maybe Daz should make their convert and export a little more refined.
FranOnTheEdge ( ) posted Wed, 02 April 2008 at 6:33 AM · edited Wed, 02 April 2008 at 6:35 AM
There's a lot in B6 that I personally would like Daz to fix, like the exporting of Bryce obp's without odd holes and reversed normals and other bits wrong that I'm not sure what they are.... just for starters.
Not to even get me started on how B6 is either ignoring or reversing the effects of any .mtl file that used to be handled perfectly okay in B5.5
.... and -
(goes away and takes a pill)
Fran's Freestuff
electroglyph ( ) posted Sun, 06 April 2008 at 8:43 AM
I should also mention if you do join or weld these objects together you loose other materials and the object becomes just a single material. You would have to map the object and paint the appropriate faces on a texture to create a Yellow, Green, Red, and Blue closed block.
Don't even get me started on how B6 mangles boolean terrain exports. There are definately a lot of things to fix on Bryce 6.
