Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 30 3:32 am)
**"Memory limit buffer
**defines the size of the safety buffer in Megabytes. If less memory is available, the render terminates. Lowering this value can avoid premature termination, but can also affect stability."
Raising the value could cause your render to abort without finishing. If you had problems with renders aborting you could lower it but may cause other problems.**
Hi Nigel,
Yes I hope so....
At General preferences>render>
memory: Adaptive bucket size
Adaption threshold=0.375000
Memory limit buffer=28
At Render Settings
(auto Settings)
for the final Render, the slide is at "Final", some time with Smooth polgons on.
and it load with 6 runtime maps(can that be a problem?) never before had problems with loading runtime-maps.
and sinds a day or 2 it loads very long 3 to 4 mins....? never had that before....and I allways have 'good renders, with on problems....
I do this with a:
PC: mobiel AMD Athlon(tm) XP-M 2800+
Speed: 2.13 GHZ, 992MB
(not on line) can't do the up-dates...
so move the file with memory-stick...
help...!!
In the general Preferences panel under the Render tab is a setting for the memory limit buffer. Could someone tell me just what this is. Mine is set at 32 but i have 4 gigs of memory. Would it be better if i increased it? Thanks for your help.
