Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:08 am)
This is known a gimbal lock. There are a couple of ways round it that I know of, probably more: - import a prop, make it invisible and parent the bed to it. Then rotate the prop instead. - export the bed as OBJ, re-import. But first, check that the prop hasn't been saved with rotations already applied to it. If it has, zero them and try rotating through other axes instead; you may not need the workarounds.
Ahhh.. HA! Dunno why on earth it didnt occur to me re importing a prop.. done it before with other items on occasions..ok.. bed is now moving how I would like it to!
Thank you so much.. my brain is in a real 'go slow' mode.. or maybe it's in a 'no go' at all mode lolol
For my own future reference tho and in the interest of learning ..
*But first, check that the prop hasn't been saved with rotations already applied to it. If it has, zero them and try rotating through other axes instead;
*how do i check something regarding whether its been saved with rotations......in the joint editor or elsewhere??
thanks appreciate the help :-)))
Quote - how do i check something regarding whether its been saved with rotations......in the joint editor or elsewhere?
No, just load the prop and look at the dials. I've seen 3DS models where the Y and Z axes are swapped over, so they need to be rotated before use in Poser - and if they're saved like that, the rotation dial setting is saved with the prop. Gimbal lock usually occurs when you try to do more than one rotation, which is why I asked; I wondered if the prop might have been saved with one rotation already done.
now that you have mentioned it.. it is... it loads with x already rotated at -90
if you zero xrotate, it is then standing upright with the foot of the bed flat to the floor .. not flat to the floor.. but in that general position..tho thru the floor.. if that makes any sense (if not i completely understand.. it is somewhat garbled lol ;-) )
That makes perfect sense. It may have been modelled in 3DS Max, which I believe swaps the Y and Z axes according to the Poser convention. So the author rotated it -90 degrees around X and saved it that way. When you tried to perform a second rotation, gimbal lock set in because Poser got its knickers in a twist. :) So when you exported the rotated model (i.e. looking like a bed should look) and re-imported it, you no longer need two rotations to get it positioned as you want. Et voila! No more gimbal lock... If you're bored, search the forum for gimbal lock and see the arguments about why Poser still suffers from this, and how many chickens should be sacrificed to make it go away. :D
will have a nosey around re the gimbal lock posts, as for the chicken sacrifices.. am sure its not the number of chickens required that poses the problem, but that ppl haven't taken note of performing the sacrifices during the full moon at the cross intersection closest to the gates of their local cemetry!
OT for a mo.. have just been having a giggle over this:
googleblog.blogspot.com/
and this:
www.google.com/virgle/index.html
haha.. just found the googe .au effort too lolol
gDay™ with MATE™ Search tomorrow’s web, today!
Google Australia has introduced a new feature, enabling you to search content on the internet before it is created.
www.google.com.au/intl/en/gday/index.html
Funny stuff... i always look forward to Google's efforts :lol:
Another thing you can use - assuming you have Poser 6 or 7 - is the Direct Manipulation Tool. It does the same thing as loading another prop.
I'm using a bed from freestuff (think from memory its Carib98's(?) lovely one)
When it loads into the poser workspace, it has the foot of the bed facing the camera. That is fine but i want to rotate the bed around the Y axis so i can have one of the sides of the bed facing the front camera instead. This is where the fun begins. If I try to y or zrotate the bed, it tips it to the left or right (side to side) in each instance..if i xrotate the bed it rotates it back and forth (front to back) from bedhead to bedfoot.
Sure i can alter the camera instead but at this stage that isnt what i want to do..
Am thinking there must be an easy way of getting around this with the bed (mayb to do with altering the orientation of the object?)... but have no real idea how.. anything i do just seems to create a headache lol
Any help/suggestions appreciated.
