Sat, Dec 28, 1:21 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 1:11 pm)
Subject: Poser 5.0 & Quicktime 7 Problem ...
miken999 ( ) posted Fri, 04 April 2008 at 5:32 AM · edited Fri, 27 December 2024 at 10:21 PM
Anyone has an idea how to work on Poser 5.0 & having Quicktime 7.0 / 7.4 installed ???
When Quicktime 7 is installed, browsing my folders in Poser 5.0 is a real pain,
it takes more than 1 minute to have access to files in folders ... without Quicktime it takes 2 seconds !
Maybe someone has a tip to fix that ...
Strangely, Quicktime 7 has no impact on Poser 7.0 ... but I use mainly Poser 5.0.
Sambucus ( ) posted Fri, 04 April 2008 at 7:15 AM
I removed all trace of Quicktime when I worked out that it was responsible for crashing Bryce when I tried to install that app. . if I need to watch a .Mov file I use realplayer.
Acadia ( ) posted Fri, 04 April 2008 at 8:45 AM
Quicktime conflicts with Poser 5. The only solution I know of is to uninstall Quicktime.
jonnybode ( ) posted Fri, 04 April 2008 at 10:41 AM
Hi Miken999!
I always save useful ideas when I browse forums, i searched my computer and found this:
quote:
If you really must have QT installed on you "puter" (as a friend of mine needed it for Illustrator),there is another workaround....
Delete the "Mac" plugin found in your Runtime>ImageIOPlugins folder.
This goes back to the legacy coding as the original Poser was ported to Mac's and used QT for display.
You don't need it...but you will see a big different in your library display.
End quote
I dont have Poser 5 installed myself so I cant tell if it works or if its safe to do this, maybe someone else remembers this trick?
Regards / Jonny
miken999 ( ) posted Fri, 04 April 2008 at 11:50 AM
Quote - Hi Miken999!
End quote
Regards / Jonny
Hi jonnybode, Thanks for your help !!!!
I can now use poser 5 & Quicktime 7.4 !!
I deleted the MAC plugin as suggested, and Poser 5 works as before :)
Thank you again ! :)
