Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
I'd try and get the latest beta patch and make sure you have administrator rights set.
LVS - Where Learning is Fun!
Also try to download those items again and make sure you click the edit button and select the correct version if Vue.
Check your built version in Vue , under help, about Vue6..., and see what built number you have, then compare to what's available at e-on's. Sometimes, you think you have the latetst version, but you don't. Happened to me many times! That said, the Haye bale pack is not the most recent object from Corn, so the problem might be elsewhere...
Best thing then is to send an e-mail to support@cornucopia3d.com. They are great and will help you out.
Are you sure that you use the exact same login data for your account at Cornucopia3D as you used it to register your Esprit at e-on? To me this sound like a copy-protection issue. That the product you pruichased is not protected to your copy of Vue.
Just a thought.
I saw the question under "Newbie Question" and my problem relates to that. I get the same error message on about 3 things I've purchased from C3D. A barn, the Queen Dovecoat and a Hay bale. I've put them in the correct directory i.e objects/architecture/purchased but still get the message that Vue can't read the file (or similar.)
I've looked for the Vue File Converter, but didn't see the file in the Program Files/e-on software directory and in the Documents folder. This is with Vue6 Esprit with the latest "final" update. I've not installed the "beta" one. I'm running Vista on this computer.
Any insight? Anyone? It's annoying as heck! :) TIA
