Mon, Feb 3, 10:54 AM CST
Forum Moderators: Staff
Subject: Can this be done?
TIRROCCIA ( ) posted Mon, 07 April 2008 at 8:10 PM · edited Mon, 03 February 2025 at 7:48 AM
I'm realy new here and I hope I'm in the right place for this "Can It BE Done In Poser" I know there are some supertalented people out there who could recreat this effect if it can be done at all. I posting a movie flyer image that has the effect on it, and I am dying LOL to know if it can be created in poser (with out or with postwork) and if so HOW? Please forgive me if i have the wrong formum and just move this question to the correct one pleaseeeeeeeeeeeeeeee; screen shot are SOOOOOOOOOOOOOO helpfull!! the "streachy" wall thing gives me dozzons of image Ideals if only..............
infinity10 ( ) posted Mon, 07 April 2008 at 10:08 PM · edited Mon, 07 April 2008 at 10:08 PM
Yes - drape a dynamic cloth over a skull prop and rotate 90 degree to vertical
updated - and, i am no expert
Eternal Hobbyist
markschum ( ) posted Tue, 08 April 2008 at 12:21 AM
Yup,cloth simulation ,  have the face horizontal looking up , and drop the hi-res prop square onto it in a cloth simulation , you only need maybe 15 frames . Use one of the earlier frames where the cloth is only partially draped.
Or select a row of points around the cloth edge to be allocated to coreogaphed group. And set keyframes at 0 with the cloth just over the face , not touching , and then at say frame 20 with it part way down the head.  Set keyframe , and run the cloth simulation . Using choreographed will stop the cloth edge from dropping .
In either case you may need a light cloth to get the tight conforming thats in the picture.
Ian Porter ( ) posted Tue, 08 April 2008 at 3:36 PM
Hi,
As an alternative to cloth simulation you could try using a high resolution plane and a group of magnets. It might not be as detailed unless you use a fair few magnets, but the effect would be real-time.
Cheers
Ian
TIRROCCIA ( ) posted Wed, 16 April 2008 at 2:19 AM
THANK YOU EVERY ONE!!!!!!
